is there anyway to get 2 new pre-cats somewhere else than the ford dealer? my svt wont pass smog because the check engine light is on and they said they 2 pre-cats are bad.
Nope. They're inside the headers and thats how they'll come to you and cost a pretty penny. Did they give the code to your or simply say it was your precats?
2000 "Amazon" Tropic Green CSVT #836/2150
so it will still pass the pollution part with the precats bad if i get the eliminators?
As long as your main cat is there and its in good shape you shouldnt have an issue passing an actual sniff test. One county over they just plug into your OBDII port (if you have one) and only sniff the older cars that dont have the port for the machine.
As mentioned your best bet is the electrical mil eliminators or the older fashioned anti-fouler trick.
iirc I have seen magnaflow replacements on ebay, but they where still pricey...
- 95 Mystique LS <-sold
- 99 Contour SE Sport
- 2k Contour SVT - #2137
Aircougar Performance
k thanks ill give it a shot.
but where do i buy the mil eliminators from?
If you want the electrical ones that you'll splice or solder in they're available lots of places online including Nautilus. If you want the screw in fouler type you can get them from the autoparts store and drill them out yourself.
