Originally Posted by
RedBeardedDevil
To be honest, I think part/most of the second gain was from gaining experience with launching, shifting, etc. I am sure it isn't good for 10000+ HP but it "seems" to help. I usually run without my stock filter in after my first few passes. Not the greatest idea I know but we wanted to try it out. I did get some better times but not by much. One other benefit is that it will shut up some well meaning friends about how I need one. And my son thinks it's cool lol. I am aware of the science of it and know that true gains will not be experienced until other mods come into play.
Running without your stock filter, but with your stock intake box would not make any difference over leaving your stock filter in. Paper filters being a restriction is a myth. Your airbox is a greater restriction.
As for replacing your intake.... it's mostly on the specially calibrated butt dyno that there is a difference. Unless there are supporting mods, you usually wont get much out of an intake. Then even with supporting mods, an intake wont usually net you more than 5 horsepower, except in an extreme case.
If you really want to learn a bit more about intakes on the cheap, search for "pudmunkie intake" You will see several threads involving short ram intakes. Although what is different about it is that that adds an air box to reduce heat soak. Most versions of it are even aesthetically pleasing as long as you arent using a cut up garbage can to make it.
96 Lincoln Continental -- Hey, D186 is a Taurus platform, and people mistake contours for an escort or taurus all the time, therefore, technically, I am not a troll.
Bookmarks
