Closed Thread
Page 1 of 8
1 2 3 ... LastLast
Results 1 to 10 of 73
Thread: #1382 Turbo CSVT numbers
    Mar 2003
    Dayton,Oh.
    664
    Default #1382 Turbo CSVT numbers
    I just got a call from the kid that bought my turbo SVT, said he took it to a local shop and they found it to be running 8% lean at WOT. The AEM A/F gauge said it was right on 12.8-12.9 at WOT when I sold it. He said this shop (Precision) said the plugs were amost burnt through due to the lean mixture. He said they "fixed" the tune and turned boost to 10#. He said he has the sheet to show it put down 310 hp at 10# on stock 2.5 motor. He said he will bring the sheet by so I can see it. I'm awaiting the painful call when he says "I blew it the F up". He also said it ran 13.85 @102 after this fix. Not sure of the track cause Kil-Kare only has test and tune on Thurs. and my neighbor saw him run a best of 14.15 ???
    More to come..
    Rod
    -2000 SVT-Silver Frost/Midnight Blue
    #1,382 of 2,150 born- 1/7/2000
    *NPG Stage 1 Turbo kit # 7 @ 8/10 psi (Sold 3/30/09)
    -2001 White Saleen S281 #720
    -2003 Lincoln Navigator-Ultimate Silver/Blue
    Jul 2006
    Cleveland Institute of Music, OH
    1,944
    those are some great numbers!
    2000 T-Green CSVT 3L #1065/2150
    2000 T-Green CSVT #0998/2150 SOLD!!!
    Oo (xxx) oO
    o xxxxxxxx o
  3. Default
    Quote Originally Posted by 2kSVT View Post
    I hate to be the one to break it to you but 12.8-12.9 A/F at WOT is lean. If that is the true A/F ratio and you drove it like that for some time it's a wonder it didn't gernade before you sold it. The absolute leanest it should be with an accurate reading (a tailpipe sensor is not accurate) is around 12.0 and that is borderline to me. For comparison a race gas file for my Cobra (110 leaded) would be about 11.7-11.8 max and my pump gas tune is 11.4-11.5. My pump gas tune is for 17 psi.
    Eight cylinders or not a A/F ratio for a FI car should be about the same regardless.
    Shannon
    99 Silver Frost SVT Contour
    Daily driven and stock... for now.
    03 Torch Red 10th Anniversary Cobra Convertible
    A stock motor, a black blower, and a few other bolt-on's...
    The replacement for displacement has "Whipple" cast into it.
    Dec 2005
    Loudon,Tn
    5,899
    310 at the wheels on a 2.5 is impressive in the least. I hope he manages to show you proof.
    2006 Cobalt SS/SC AEM intake and nothing else atm......
    2000 GT Vert 18x9/18x10's, light bar, system...
    GONE 98 #0895 3L, 99 #2439, 98 #0474 3L, 98 #0844
    So if it turns out he was right and the tuner fixed the problems in the tune is your ego gonna be able to take it?
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind." -- Dr. Seuss
    Fastest Troll SZ10 without training wheels
    Oct 2004
    Northern MN
    7,840
    Quote Originally Posted by Kilroy View Post
    Shannon
    I have been told the 11.5-11.9 that my NA runs at WOT is rich.
    04 BMW X3
    99 Toyota Solara And one Peppermint Patty
    99 3.0L SVT Silver Frost #1264 Sold 1-22-10
    95 SE MTX---Sold 9/14/07 sniff
    98 E1 SVT #4892 of 6535T-Red Sold 8-29-08
    Apr 2002
    Durka Durkastan
    3,035
    Contour's have typically run very well at leaner AFR's than is typically expected. Mostly because the engine seems to have a very good combustion chamber design.
    The only real reason you try to run richer is to cool down the combustion chamber to prevent detonation. If however the combustion is resistance to detonation you can run a leaner mixture for better power.
    The 11.7 is typical for a Forced Induction tune because it is the Rich Best Power point for gasoline and the extra fuel helps to keep things cool.
    04 Subaru WRX - 12.638 @ 111 Corn Powered
    SZ Top Troll '06 & '07
    SZ Fastest CEG'er '06 & '07 & '10 (w/ 4 wheels)
    Nov 2005
    wales ma- it's next to holland (check the map)
    1,252
    Quote Originally Posted by elraido View Post
    it is rich, but that is irrelevant to the topic because yours isnt turbocharged.
    2004 F150 XLT/ 93 RX7 touring-soon to be ls1/65 Mustang fastback- project EFI 351TT
    SOLD: 98 SVT #2663,89 Mustang GT Twin Turbo, 00 SVT #985-SF,98 SVT #948 BLK/Tan E0, 99 SVT #587-T-green,98 SVT #3969 blk/MNB
  9. #9
    I thought I just saw a video of the dyno on youtube or streetfire or something. The description in the video said it was running lean and the dyno op wouldn't go any further. I thought it was showing 330whp or around that...I am pretty sure it was this car.
  10. #10
    Dec 2005
    Loudon,Tn
    5,899
    Quote Originally Posted by 2000ZxT View Post
    the car you saw is black lol his car was silver not to mention that vid is almost 2 yrs old now lol if i just found the one you were talking about
Closed Thread
Similar Threads
  1. Forced Induction FAQ
    By beyondloadedSE in forum Forced Induction
    Last Post: 08-24-2009, 10:34 AM
  2. Stock 3 liter Turbo NEW NUMBERS
    By BurritaSVT in forum Dyno and Drag
    Last Post: 08-03-2008, 07:09 PM
  3. New look at street car intercooling
    By cuda06 in forum Forced Induction
    Last Post: 06-13-2007, 06:37 PM
