Myrosia
Hey guys. I never had any leaks with this car before.
It's 1999 Contour, 4L, DOHC.
After I replaced the valve cover seal, a few weeks later when having my oil change, they mentioned I had a leak under near engine and tranny meet. They said it might be the rear main seal.
So,
1. is it a coincidence I change the valve cover seal then I get this leak?
2. someone said to check the PCV valve although, I replaced that last year.
3. for now, what's the best recourse to correct the leak without having to replace the rear main seal?
Thanks
So,
Thanks
