Knauberizeing made easy and quick
95_Mystique
Middletown, Pa
What you will need...
Bondo applicator
cordless drill
astro smart eraser pad... http://www.goodspeedmotoring.com/astro-eraser-wheel-400e.html
First, start to pry the ding gaurd off with the bondo applicator by sliding it between the door and the ding gaurd. Get it off far enough to get your fingers under it to pull it off. Go ahead and do this to all 4 doors.
Next, get the smart eraser pad and put it into the drill. turn on the drill and and watch the eraser pad do all the work. This will knock a very good portion of time off of the old way of using fingers and finger nails.
i used my finger nails and my health card ...
but im impressed with the result
nothing like a couple hours and a couple beers :)
i used the old method on my GL, and that was not only a pain but also very time consuming. i picked up one of those smart erasers to do my SE and to remove the pin striping, worked beautifully. instead of an entire afternoon wasted I got wasted the entire afternoon... J/k but thanks for recommending this product.
