Closed Thread
Results 1 to 6 of 6
Thread: FAQ: 2.5 Bolt-on basics
    Post FAQ: 2.5 Bolt-on basics
    =Updates=
    FAQ - Bolt-on Basics is dedicated to performance modifications that involve little to average mechanical ability.
    If you want to get more serious about modifications, check out FAQ - Serious Modifications.
    =Areas covered in this FAQ=
    Chips
    Coatings
    Exhaust
    Headers
    Heatshields
    Intakes
    MAFs
    MIL Eliminators
    Motor Mounts / Poly Roll Resistors
    Mufflers
    Oil filter relocation
    Resonators
    Short throw shifters
    "Snake Oil"
    Throttle body / Optimization & Services
    Y-pipes
    Post
    =Chip/Tuning=
    A chip/PCM reflash is recommended as one of the last modifications you want to do, although it is not neccessary. Having it tuned is the most important part, and it will be tuned to your existing modifications. There's essentially three different kinds of methods of tuning you can get. First, you can get a chip which is tuned specifically for your vehicle. No tweeking is available. The tune on the chip is what you get. Remember, a brand of chip (Superchip, Diablo, etc) really is not what matters, but WHO tunes it. If you want the most gains, you want someone to tune your car that has a great deal of experience with this platform. Secondly, you can get an SCT X-CAL 2 which is a device that you can plug into your OBD-II port and reflash your PCM's stock tune. Again, this is pretuned much like a chip, but is vehicle specific. Whats nice about this is you can upload multiple tunes into an X-CAL 2 to see which works best for your car or something like a N/A tune or a nitrous tune. Minor tweeking such as timing can also be performed with the SCT X-CAL 2. It also acts as a CEL scanner. Finally, if you want to do your own tuning, you can get the SCT Pro Racer Package (PRP) which lets you fully tune your car yourself. This isn't for a novice tuner, but options are endless.
    Most recommended/used:
    Nautilus Performance
    =Coatings=
    Coatings for your headers, exhaust, UIM, etc. will reduce the temperatures and add durability to the parts.
    High Performance Coatings
    Jet-Hot Coatings
    Swain Tech
    =Exhaust=
    A bolt-on cat-back exhaust will result in 4-8hp depending on brand and modifications to your vehicle.
    Bassani - Discontinued
    - removable resonator tips to reduce sound
    - loud and drones
    - raspy when cold
    Borla - Discontinued
    www.ctamotorsports.com
    www.batinc.net/contour.htm - page 33
    - smooth sound similar to stock
    Bosal
    www.batinc.net/contour.htm - page 34
    - loud with mirror finish
    - flange-fit exhaust may cause some installation problems due to inability to adjust
    CTA
    - Magnaflow mufflers and resonators options available
    - 2.5" all the way back or 2.5" -> 2.25" available
    TruBendz
    www.trubendz.com
    - 2.5" bolt-on cat-back exhaust
    - many consider best "bang for the buck" exhaust
    - many muffler and resonator options available
    =Headers=
    How-to: Headers by CEGer Tourige
    Headers FAQ by CEGer Tourige
    MSDS www.msdsinc.com
    - short tube headers
    - realistic gains 5-15hp+ depending on other modifications
    Weapon-R - www.customcougars.com Discontinued
    - known as MSDS knockoffs
    SHM Long Tube Headers Discontinued
    - have been discontinued for quite some time now but were the only long tube headers available, $1200 NEW when they were offered
    - provide more low end torque compared to the shorty MSDS headers
    Post
    =Heatshields=
    CEGers have used various methods and techniques to create heatshields. Some are cheap and easy, others a little more expensive and more creativity.
    Search: heatshield
    CEG'er Pudmunkie also sells heatshields. Send him a PM.
    =Intakes=
    AEM Intake System
    BAT
    www.batinc.net/contour.htm pages 22 - 25
    Most popular open filter: K&N RU-3530
    www.ajusa.com
    Most popular CAI: Nautilus Performance
    Click here to see sample picture of intake installed
    KKM
    KKM intake
    =MAF Adaptors=
    www.batinc.net/contour.htm page 23
    CTA Motorsports
    www.ssd4u.com ***Added 7/6/06***
    CEGer J3SVT: They are sold with hardware and the K&N on the website, but CAN be purchased separately if you e-mail or call them and ask ONLY for the maf adapter. They are made specifically for the ru-3530 and are made from hardened polyurethane. I paid about 26 dollars shipped.
    KKM MAF Adaptors
    Post
    =MAF=
    The stock MAF can support about 280-290FWHP safely.
    There is not a "need" to upgrade until then.
    Larger MAF discussion
    Recent MAF discussion
    =MIL Eliminators=
    MIL Eliminators
    =Motor Mounts / Poly Roll Resistors=
    Front and rear - Purchase from CEGer pole120
    =Mufflers=
    Magnaflow - most popular, most recommended
    Flowmaster
    Dynomax
    Borla
    Magnaflow mufflers can be purchased from www.justmagnaflow.com - CEGer Stazi does NOT sell them anymore!
    =Oil filter relocation How-to=
    How-to by CEGer todras
    =Pulleys=
    CEG member 96BlackSE sells underdrive power steering and alternator pullies. Might free up a couple hp. Send him a PM on availability.
    =Resonators=
    A resonator will result in 1-3hp depending on modfications to your vehicle, and provide a nicer sound.
    Magnaflow - most popular, most recommended (4" round straight through muffler")
    Used by CEGers: #10435 and #11225
    Where to buy:
    Post
    =Short Throw Shifters=
    Cutting your shifter down is not a short throw shifter!
    B&M
    Can be purchased at Ultra Rev
    - shifter is shorter than stock height
    - 1st true short throw shifter
    Steeda (MTX-75) - Discontinued
    Steeda
    Ebay
    - shifter is close to the same height as stock
    - an adapter plate is needed to install
    OBX
    Ebay
    - considered to be poorly made
    - reinforcing the weld at the base generally solves the problem
    =Throttle body=
    TB Optimization from CEGer pole120 - optimization by hand
    TB Optimization by machine TB Optimization by machine - contact CEGer scottd60
    Optimize the SVT TB
    Optimize How-to on Main site
    Install How-to in Duratec Performance
    2.5Ls will not benefit from a larger throttle body like the Mustang 65mm) unless you are running some kind of Forced Induction. Save yourself money and Optimize the SVT TB.
    =Y-pipes=
    A y-pipe will result in 4-8hp depending on modfications to your vehicle.
    Tru Bendz
    - stainless and aluminized
    - realistic gains: 4-8hp depending on other modifications
    Post
    =Snake Oil=
    The following products are nothing more than marketing hype and wont do you any good:
    - Tornado Fuel Saver
    - Ebay Performance Chips/Modules/Resistors "good for 20+hp"
    If it sounds to good to be true, it probably is! No single bolt-on that costs a few bucks is going to yield 20+ for this engine.
    FAQ: Misconceptions / debated subjects, snake oil
    =Suspension=
    Tubular Toe Control Arms - CEGer Bradness
Closed Thread
