IMRC cable repair
Here's how I repaired my cable.
-Remove IMRC from engine
-Disassemble IMRC by removing cover. I used a razor blade to cut the silicone from the housing.
-Remove the circuit board, motor, gear and shaft (carefully pry loose the retainers), nylon gear and cable from nylon gear.
-Cut off barrel end as close as possible. save the barrel end. Remove inner cable from outer plastic.Take a measurement of the inner cables length.
-Using a low speed drill and a 1/16 cobalt drill bit ($3.00 at local hardware store) drill hole through barrel.
-I tried using several different cables from the local hardware store. Neither will work due to the hardness of the cable. Use automotive grade cable.
