OK. If anyone's interesting in a nice early morning ride on Sat/Sun, the bike is ready. Here's the latest update that I posted on the old BBS (thanks fbc2!)
OK. So I FINALLY had some time to finish putting the bike together.
- Got a rust-free tank, ground off the finish and primed it yesterday.
- Ground off the rust and scale from the pipes and painted with high-temp manifold paint.
- Replaced both exhaust seals.
- New upper fuel petcock installed.
- Cleaned lower fuel petcock and fixed a vacuum leak to carbs (Now PRIME, RES, and ON work properly). New one is on order anyway.
- Rebuilt carbs with new bowl gaskets, float needles and o-rings. Cleaned with carb cleaner (lots of old fuel deposits)
Funny thing about the carbs, the float needles were in the wrong holes, so they weren't floating at all; they were jammed into the main jets. Explains why the carbs kept filling with gas and overflowing.
Took her our last night and she works like a charm. Going to double check the rear alignment and then try for a longer ride some time this weekend. Anyone wanna come?
It's not like I'm far away.
