Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: MTX don't shift (NOT THE COMMON ISSUE)
    Exclamation MTX don't shift (NOT THE COMMON ISSUE)
    Hi Everyone!
    I have been here since a couple of months but never registered , but now, my only hope is your help about this, sorry for bother you in this way in my first Thread.
    I searched in the old forum and all what I found was the same questions with no accurate answers, so I just want to know how resolve this, with no speculations, there are enough speculations in the old Forum.
    The MTX of my CSVT has a lot of problems to shift into 1st, 2nd and reverse when the car is in neutral . It doesn't matter if the car is cold, hot, or if is day or night, it happens in all circumstances. I tried pump several times the clutch, but there is no difference, it's like if I want to insert a stick into a solid wall. There are no sounds, no noises, it just don't shift. The only way that I can shift into 1st or 2nd, is turning OFF the car, shift into 1st, and then turning ON the car with the stick in 1st. Other way that I found was shift into 3rd, move the car a little and then shift quicly in to 2nd or 1st.
    When the car is running, there are no issues about shifting, just in neutral with the car stopped.
    I already changed the fluid with Mobil 1 Synthetic Mercon, but I readed here that the ATF +3 +4 from chrysler work better because the friction modifier ammount, so I changed the oil again with Valvoline ATF +4 Full synthetic yesterday. There were no difference at all. (I didn't buy MTF because im in mexico, and I couldn't find any MTF with the GL-4 specs, just GL-5)
    I read in the old forums that could be the pressure plate, the slave cylinder, the forks, well a lot of "...that could solve the issue" posts, but I couldn't find at least one popst saying "this resolved my issue". So, please I beg for your help, I'm already in my knees!!!
    Thnxs 4 any help.
    Kenshin
    98 Black CSVT - 97k miles, 1300w Xplod, K&N.
    WTB: 3L Block w/heads
    WTB: SVT stage 1 clutch (new or used)
    Sep 2000
    7,332
    The clutch is not fully releasing. With a little luck it is just from air in the hydraulic clutch linkage system. Try flushing the fluid so you have fresh fluid and can fully bleed out any air.
    The clutch fluid shares the brake master cylinder resevoir. The slave cylinder bleed port is on top of the bell housing. You will need to remove the intake air tube between the air filter box and the throttle body for access.
    Suck out as much brake fluid from the brake master cylinder as you can with a turkey baster and add fresh fluid.
    Have an assistant pump the clutch pedal about six or eight times and while the pedal is down open the bleed port. Repeat as many times as needed until the fluid coming out is as pristine as the new fluid from the bottle.
    Flush the brakes while you are there. Refill the master after the clutch and after each wheel.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Jun 2005
    Virginia, USA
    11,070
    Welcome .
    "Entiendo un poco espaņol"
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Did you check the state of the bushings at the end of your shift cables? If it's worn or missing it wil cause the same effect. Might want to add your city and state to profile. A CEGer would probably meet to check it out for you.
    My car did that when I bought it, until the time my new clutch was installed. It was so annoying.
    Trying to parallel park the car in traffic and all you can do is sit there and not get into gear. I shut off the car, put it in gear, then started it.
    1998 SVT Contour (B/MNB) #542 3L
    2000 SVT Contour (SF/MNB) #1533
    2003 BMW 540i M-Sport (6 spd)
    2002 Lexus IS300 SOLD!!
    sound like the shift tower removve the shift tower from upper and check for loosing movement
    CSVT 98 #1862 of 6535 06/11/1997
    3.0,tw8mm,msds-h,2.5exhaust ,optimized y pipe, superchip,original svt cams, unorthodox udp,stage 1 spec clutch,optima yellow battery
    GTP 2002 no cat,original intake,mil eliminator,u bend deleted, 9.60 1/8 mille stock
    Thnxs everyone for your info!!! I'm gonna to bleed the brake/clutch and check the bushings of the shifter cables this weekend. I hope this solve the MTX issue. I will inform the results the same weekend.
    If anybody has another suggestion I will really apprecciate it! Thnxs a lot.
    P.S. Im in Mexicali, BC in Mexico. It's a border city with Calexico, CA, if anybody is near and have a little time free, I will apprecciate help . THNXS again
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Yea the guy right above you. LOL! RRT SVT. I don't know how much help he'll be from some of his posts though. LOL!
  9. #9
    kenshin yo tambien soy de mexicali we jojo anota mi msn we antonio_apmicrotech@hotmail.com
  10. #10
    Quote Originally Posted by todras View Post
    ahahaha Too funny.
    My project website
