Results 1 to 6 of 6
Thread: rust
    Question rust
    I just discovered rust underneath the gas door. Its right above were the bumper meets. I also have a small amount of rust on under my drivers rear door. Underneath the door skin. The rust is still smooth and is not grainy and breakable. Its still very intact. It must have just started. I am not happy to find rust on my car. What do i need to do to stop it?
    2000 CSVT- Silver Frost #1580 -the silver bullet-
    Dec 2001
    Enfield, CT
    20,538
    Blog Entries
    93
    you need to get in there and remove it and get a good rust inhibitor on the metal then some paint ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Aug 2004
    ILL, CHICAGO
    2,811
    Good thing you saw it before it gets worse. Under the door simply grind down the rust to the bare metal and prime it and paint over it. The key to get rid of rust is to get it down to bare metal. If you dont it will come back.
    03 Mustang Cobra Convertible # 476 out of 5,082
    93 Cobra
    01 Lightning
    99 LX Contour - Sold 2/23/09
    Jun 2004
    Kitchener, ON Canada
    1,996
    yeap, make sure you get it all too, Ive always been told to to grind down to bare metal and go a good 2 or 3 inches past where the rust has been, so theres no chance of it coming back. I touched up a spot last summer, but some must have been up and under the the rear quarter panel because it came back this year.
    95 Mystique 2L Auto
    98 SE Contour Auto
    98 Taurus Vulcan Auto
    Jul 2004
    International Falls, MN/Stevens Point, WI
    556
    grind it down to bare metal then put some rust convertor on it. this will convert the rust thats left that you can't see to a primer. paint it right after it is done curing and it won't come back. I had a 91 explorer with rust on the tailgate that kept coming back after i kept sanding and painting it and after i hit it with rust convertor it stayed gone. Do not get the spray can stuff- it is useless from my expirience. get the stuff that paints on- i got it at Napa and it works great.
    May 2004
    Calgary, Alberta, Canada
    4,506
    oi. Rust sucks.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
