Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: stock tire psi
    Default stock tire psi
    I've searched and cannot find the answer. Checked the driver's door, the manual, and the site. I cannot seem to find the correct tire pressure for standard 14" tires. I've been running 35 in all 4.
    96 Contour GL 2.0, ATX "Herman" 109K
    "A maintained zetec is happy zetec"
    32 is what is spec'd. Because of my crappy tires on my 96. I run their max which is 35.
    98.5 SVT-187whp-whawhawheel bearing.
    96 ATX Zetec-alive but scarred!
    FS: $100 off $200 or more SPEC purchase
    I was thinking 32.
    Thanks
    However I put two bags of sand in the trunk (70 pounds on each side). Should more or less air be in tires with this weight?
    I have 35 in now.
  4. Default
    Why would you put sand in the back. Id hope not for traction.....
    yeah for traction.
    I've had a few too many close calls with skids in the winter. Almost hit a guardrail after the last skid i had without the weight.
    A few in the middle of intersections.
    Haven't had any problems with the weight, just without.
  6. Default
    Or just keep a full gas tank But, I've always thought weight in the trunk of a FWD would counterbalance wat needs to be in the front
    Weight in the back won't help with traction (trying to get up a hill or something), but it will do good things if you have a habit of sliding your back end around corners.
    In the end, you're better off loosing the weight and getting some snow tires for the back that have good lateral stability (many snow tires seem to lack this).
    1995 Contour SE
    2.5L ATX (stock so far)
    47k Miles @ 11/13/2006
    62k Miles @ 08/01/2007
    Jun 2004
    Kitchener, ON Canada
    1,996
    if your going to put on snow tires put on 4 of them. Your only going to get the full benefit of snow tires with a full set.
    95 Mystique 2L Auto
    98 SE Contour Auto
    98 Taurus Vulcan Auto
  9. #9
    Jul 2000
    Upstate NY
    1,102
    Quote Originally Posted by zetec herman View Post
    yeah for traction.
    Um...
    Your car is a front wheel drive. If you want added traction, you would need to take the bags of sand out of your trunk and somehow affix them to you hood.
  10. #10
    Oct 2005
    Toledo
    1,188
    Quote Originally Posted by 96RedSE5Sp View Post
    Um...
    FWD cars understeer.. unless of course the handbrake is involved
    TRed CSVT on FSVTs.. in pieces for now!
    http://www.cardomain.com/ride/2154233
