Results 1 to 4 of 4
Thread: Interior parts and pieces
    Sep 2006
    Portland, Orygun
    1,393
    Default Interior parts and pieces
    going to the dump tomorrow rather these go to someone needing them
    1 pumice rear window brake light
    2 cruise control wiring harness w/ buttons
    1 gray steering wheel … no air bag
    1 steering column
    1 set pumice steering column trim
    1 tilt steering column
    2 multi switch (bright head lights and turn signals)
    2 wiper switch
    1 pumice grab handle (over front pass door)
    2 rear coat hooks (over rear doors)
    1 set pumice door panels for crank windows
    1 set of manual window regulators
    1 pumice glove box w/ glove box top cover
    1 pumice Mystique driver side under dash kick panel w/ glove box
    2 tan rear grab handle hooks (for grab handle over rear doors)
    1 driver door window vent
    1 pumice pass door window vent cover
    1 ATX shift handle
    1 set gray / power window door handle bezels
    1 set pumice / manual window door handle bezels
    2 flat style master window switch
    7 single window switches
    5 door lock switches
    1 set rear door sails (95)
    1 pr pumice front bucket seats (95)
    1 set pumice rear seat belts
    Proud Dad of a US Marine
    99 Contour SE Sport / V6 MTX
    95 Contour GL / 4banger ATX - Like no other.
    "its not shot it just grinds a little when going into third" - tjzollman 2/25/08
    Try to be as good a person, as your dog thinks you are....
    hey do you have the windsheild wiper replay switch? the one i have in my car works but it doesnt have the speed adjuster. im guessing that will work on my 99 se zetec.
    1995 Contour GL Zetec with 116k miles.
    1999 Ford Contour SE Zetec with 145k miles.
    AIM Name: ContourAlf
    Yahoo IM: Contour_Freak
    WANTED...
    7 spoke SE rim center caps for a 95. PM me if you got one.
    Dec 2001
    Enfield, CT
    20,535
    Blog Entries
    93
    the grey steering wheel, is that the pre98 gray or does it match the post 98 greystone interior color and if so what is the condition?
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Sep 2006
    Portland, Orygun
    1,393
    Quote Originally Posted by contourfreak22 View Post
    Yes, I have the adjustable dely one. $10+ship
    It was a pre98, I don't come across much 98 or later stuff, but the other day I did see a couple. Just don't recall if they were gray. Which one are you needing?
