ButtonPuncher
I've gone through a few different versions of my CAI. Here's the third. Sorry only for MTX Zetecs...
1 - 2.75" elbow (for throttle body)
1 - 2.75" to 3" transition
1 - 15" of 3" O.D. stainless steel pipe - cut into one 6" long piece and three 3" long pieces (I bought a 3' piece and kept the scrap for future projects)
1 - 3" long piece of 2.75" O.D. exhaust pipe (I bought and exhaust tip from AutoZone with the right O.D. and hacked the ends off)
3 - 3" 45 degree elbows
1 - 3.25" to 3" adapter (for MAF intake side)
1 - 3" cone filter
14 - 3" liner clamps from Global Industrial
1 - small black garbage can from OfficeMax
4 - wire ties (two to hold the MAF to the driver's side motor mount, two to hold the garbage can to the frame)
The 3" long pieces of pipe (one 2.75" and the three 3" in diameter) are used for the connections between the silicone transitions/bends/elbows.
You can use regular hose clamps but I like using liner clamps because they don't dig into the silicone hoses. Normal hose clamps shred silicone hoses.
On pre-98 Zetecs, we have a seperate IAT (intake air temp sensor). That is what you see glued to the bottom of the stainless steel straight piece. I cut it out of my stock intake. You 98+ guys have a 6-wire MAF so the temp sensor is built into your MAF housing.
BTW, for those with a return style fuel system, I had to use a shorter adjustment screw on my Aeromotive adjustable FPR so that it wouldn't rub on the intake hose.
Filter was a little low on the first try:
MAF wire tied to trans/airbox mount:
I really didn't want the radiator fan blowing hot air directly on the filter. I remembered Pole120's garbage can heatshield idea. A quick trip to OfficeMax and I was all set. First some test fitting...
You can see my markings on here...
After chopping... (I used an air body saw to cut the can, like this one from Northern)
I cut the bottom of the garbage can completely off. I didn't want to create a vacuum by only having one end of the garbage can open.
Back in the car...
I should take another pic from the side. The can follows the bottom edge of the frame perfectly. It doesn't stick down below the trans. In the above pick, there is a bit of an optical illusion.
After I get my Walbro fuel pump in, and it gets warm out, I'll have to get some audio of the intake. Not as loud as a CTA, but still very good.
BP
1 - 3" cone filter
Back in the car...
BP
