Closed Thread
Results 1 to 4 of 4
Thread: Duratec Maintenance - Read First
    Post Duratec Maintenance - FAQ - **Read First**
    Duratec Maintenance is just that - maintenance-related posts regarding the 2.5 Duratec.
    FAQ: Where to buy parts
    Modification and Maintenance Forums Suggestion Box
    General Maintenance Schedule
    -=Oil=-
    Everything you want/need to know at Bob is the Oil Guy Forum
    Duratec Maintenance How-Tos/Fixes
    FYI: Those marked with "->" are good links. Those marked with "-" are broken and yet to be found and updated.
    A
    ->A6 sidemarkers - see Sidemarkers
    ->Air Bag Replacement
    ->Air Conditioner, Compressor/Condenser install
    ->Alternator Replacement by dartsoccer
    ->Alternator How-to by Ray
    ->Alternator wiring fix (flikering lights, low rpm)
    ->ATX - see Transaxle below
    ->Auto-Down Window, Passenger side Add-on
    ->Battery Relocation How-to by ChattavegasSE
    ->Brake Fluid Flush/Replacement: Pedal Pumping Style By Big Jim & Andy W.
    ->Brake pad replacement
    ->Brake FAQ that contains info
    ->Cabin Air filter replacement - by 69Boss302
    ->Cabin micron air filter replacement
    ->Coil Pack testing
    ->Coolant Flush by Big Jim
    ->Cowl Screen removal (wiper/motor/filter cowl) - by 69Boss302
    D
    ->DMD (Dual Mode Damper) install How-to
    ->Door Panel Replacement
    ->Door sail panels - see Sail Panel
    E
    F
    ->Fuel filter How-to by PlatoSVT
    ->Fuel Flapper, slow fill
    ->Fuel Pump, Focus SVT How-to by Pale Horse
    ->Fuel Pump, Focus SVT How-To
    ->Fuel Pump, installation discussion and differing approaches
    -FSVT Fuel Pump (in place of stock pump)
    ->GAS (see FUEL)
    ->Grill, Mesh - SEE Mesh
    H
    ->Headlight, Remote entry flash disable
    ->Heated mirror recontent - SEE Rearview Mirror
    ->Hood lift kit install
    ->Hub replacement by Ray
    ->High beam/starter mod - SEE Starter
    I
    ->IMRC Fix How-to by C. Hightower
    ->IMRC Fix, abbreviated How-to
    ->IMRC Fix Tips, notes
    ->IMRC Clip fix How-to by oberthecat
    J
    K
    L
    ->Lift kit, Hood - See HOOD
    ->LIM (Lower Intake Manifold) see UIM below
    ->LIM linkage bushings (dealer is EXPENSIVE!) replacement alternative!
    ->MAF (See: Sensor: Mass Air Flow)
    ->Mesh, Pre-98 Grill How-To
    ->Moosing (loud reverberating noise from intake)
    ->MTX see Transaxle below
    N
    O
    ->O2 Sensor Replacement - Upstream bank 1 by mycainsbroken
    ->O2 Sensor Replacement - Upstream Bank 1 thanks Goldentour
    ->O2 Sensor How-to - Rear by Antiramie
    ->Oil - How to change. by Derk2000
    ->Optimize, Y-Pipe - See Y-Pipe
    ->Painting your car
    ->Polishing your car
    Q
    ->Radiator replacement by Ray
    ->Remote entry headlight flash
    ->Rearview mirror, heated element recontent
    ->Sail panel - Rear door sail panel install
    ->Secondaries (see LIM)
    ->Sensor: Mass Air Flow, cleaning
    ->Sidemarkers: A6 sidemarker install
    ->Slow fill (see FUEL Flapper)
    ->Spark Plugs & Wires How-to by Derk2000
    ->Spark plug replacement by Ray McNairy (R.I.P)
    ->Spark Plug replacement Aide w/Pics by Ray
    ->Starter security/High Beam How-To
    Throttle Body, cleaning How to by Big Jim
    Throttle - Hang fix
    Transaxle - ATX fluid change by cobrawannabe
    Transaxle - ATX fluid change w/pics by Starjammir
    Transaxle->MTX fluid change
    Transaxle - MTX drain and fill by Ray and PlatoSVT
    Transaxle - Purchasing source
    U
    ->UIM - Cleaning intake manifolds without removing them by Big Jim
    ->UIM AND LIM Rebuild w/ pics
    ->UIM and LIM cleaning tips & tricks
    V
    W
    ->Waxing your car
    ->Waterpump & coolant replacement thanks todras
    ->Waterpump How-to, pics.
    ->Waterpump replacement
    ->Waterpump replacement - By 69Boss302
    ->Wetsanding your car
    ->Wheel Bearing replacement (W-Pics) by Ray
    ->Wheel Stud replacement (video)
    ->Window, Auto-Down Passenger Add-on
    ->Window Channel replacement
    ->Window Glass replacement
    ->Wiper Arm removal (Windshield wiper) - by 69Boss302
    X
    Y
    ->Y-Pipe Optimization how-to
    Z
    Post HOWTOs moved from old forums to HOWTO forum
    Added to:
    Duratec How-To forum
    M&M How-to forum
    Duratec Maintenance Forum FAQ
    How-to: Air Bag Replacement
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    Added to:
    M&M How-To
    Duratec Maintenance How-to
    Wiper Arm removal
    Cowl Screen Removal
    All done by 69Boss302. Thank you!
    .99 Silverfrost
    |_|0|_|
    |_|_|0|
    |0|0|0|
Closed Thread
