Results 1 to 10 of 10
Thread: 1998 Headlight Adjustment
    Oct 2007
    Blaine
    3
    Default 1998 Headlight Adjustment
    So my g/f just picked up a 1998 2.0L GL. Its a nice little car, somewhat clean. I just put about 4-5 hours and over $250 in upkeep and repairs, most of the time and money went into the alternator install. Anyway the driver's side headlight is misaligned and points down, instead of out and away from the car. I have aligned headlights in the past but I haven't a clue on how to align the headlights in a 1998 Contour.. alittle help
    Apr 2008
    North Texas
    3,570
    You obviously know how to pop the hood but you didnt bother to open the manual and look at the headlights themselves?
    2000 "Amazon" Tropic Green CSVT #836/2150
    Dec 2008
    Brick, NJ
    756
    I need to do this too. The guy I just bought mine from installed new OEM units right before he sold it and they are REALLY badly misaligned. So I take it instructions on how to are in the owner's manual? Hope so and I actually am not sure if there is one in the glove box lol.
    edit: Just found how to do it on the googlemonster. Amazing what 2 minutes of search engines will do.
    -00' Contour SVT #1245 of 2150. Trubendz Borla exhaust, BAT Catted Y, Spec shifter, Injen CAI, NPG Big Brakes, Modded Sunroof.
    -98' Mustang GT. PI Engine, exhaust, Cobra front bumper/R hood, 3.73s, deep dish Bullitt rims, lowered, lots of other stuff.
    Jul 2001
    Humble
    10,828
    hehe.. That's lesson one of CEG.. search before posting.
    Lesson two is about to come: "When you finish a problem or find the answer to a question you asked, don't just walk away happy.. POST IT.. post the answer, the link, the how-to, or the pictures in order to help others in the future that find THIS thread.
    Glad you found the instructions... now post that link!
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    Oct 2007
    Blaine
    3
    Quote Originally Posted by Dyoel182 View Post
    Yeah it didn't come with a manual, again its a used car and the trusted Haynes manual only covered the 1995-97 headlight adjustment.
    http://safemanuals.com/user-guide-in...D/CONTOUR-1998
    Dec 2008
    Brick, NJ
    756
    1- There are built in levels in these headlights, the bubble level is for up/down and the caliper type one is for horizontal. The bubble gauge is blatantly obviously right there, the caliper looking one you have to peer down by the outside corner to see.
    2- The big screw next to the level adjusts vertical and the screw with the really long shank going down by the outside corner of the headlight does horizontal.
    3- The rest should be self explanatory, adjust as needed and make sure the adjustments match on both sides to maintain symmetry. Its pretty easy to figure out just by looking at it actually. There are 2 phillips head screws sticking up out of both headlamp units that don't hold it on so they're the ones to adjust.
    Sep 2000
    7,295
    And find a level spot to park to make the adjustments, preferably facing a wall at night so you can fine tune the adjustment by sight as well as using the built in indicators.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
    Dec 2008
    Brick, NJ
    756
    Drove mine this morning and the adjustment was still way off even with the levels being dead on. What I will do tonight is to go to a big parking lot, turn the lights on and adjust them manually. Probably what I should have done in the first place lol. Oh well they are probably the easiest light fixtures to adjust ever.
  9. #9
    Jul 2003
    Rockenhausen Germany
    4,635
    My guess is that you aimed them with the car not parked on a level surface... If you park the car with the front facing up, the headlights will be pointed at the ground using the bubble levels, and if the front is facing down, the headlights will be aimed up.
    \m/ 2009 Jetta TDI \m/ 2003 Sentra SE-R Spec V \m/
  10. #10
    Dec 2008
    Brick, NJ
    756
    Screw the levels, I parked it and adjusted them manually. The right one is still a little off but I'll fix that tomorrow morning while the car is warming up with about 2 turns of a screwdriver.
Similar Threads
  1. HVAC & Headlight Switch Overlay
    By Project SVT in forum Group Buy
    Last Post: 10-24-2008, 09:14 AM
  2. IC: HVAC & Headlight Switch Overlays
    Last Post: 08-25-2008, 08:49 PM
  3. light in headlight switch
    By hgitter in forum Lighting
    Last Post: 06-23-2008, 04:49 PM
  4. Headlight Pictures Thread
    By Blacksilver in forum Pics and Videos
    Last Post: 04-29-2008, 03:36 PM
  5. Ebay Headlight
    By 2000SE in forum Lighting
    Last Post: 03-17-2008, 07:23 PM
