Results 1 to 9 of 9
Thread: IMRC - intermittent?
    Default IMRC - intermittent?
    I should have asked the seller why the IMRC cover was off when I bought my car (plus a dozen other questions...C.org member). Anyway, I finally took my C-SVT up to triple digits - on a privately owned road, of course; mods...
    In fifth, it took forever to hit 100mph; in fourth, it got to 110mph...I expected 125.
    The IMRC is not pulling the secondaries open. I feel nothing around 3250 rpm, but maybe something at around 4k. I revved the engine in the driveway and the cable was pulling. The intake sound got deep a couple of times, but not everytime. The cable was pulling each time I got to higher rpm.
    What are the common problems? Cable binding? My 1995 Escort GT pulls harder than this car over 4k rpm!!
    Quote Originally Posted by michael.lavander View Post
    Hi Michael, the cover may have been taken off because the heat from exhaust and engine was affecting the imrc. You could try relocating it. ( search..it's been covered) The imrc operates at about 4k when you accelerate with part throttle and about 3400 when WOT. If you can't really feel any kick...you may need to clean your intake manifolds (search..been covered too). If you're still not happy after that lot...maybe upgrading intake and exhaust parts may get you closer to what you expect from your car. 110 to 120mph is about right for 4th gear with stock wheels and transmission...G.
    Jan 2008
    Fort Worth, TX
    1,565
    It shouldn't take long to hit 100. If your IMRC was not working, you would know it because the car would basically have NO acceleration above 4000. Try opening the IMRC case, pulling out the circuit board and motor, and spray the motor out with CRC Electrical Cleaner, then let it dry and put it back together. If that doesn't work, it's time for a new IMRC. Pick up one at the local junkyard for $10-20, or from a CEG'r for $40-50 shipped. Before you do that, check the silver rod right under the LIM, near the throttlebody to make sure that the front bank of the secondaries didn't come undone.
    Something Green
    2009 Pontiac G8 GT
    2000 SVT #0801 (sold)
    2000 3L SVT #2094 (sold)
    Jun 2006
    Center City, MN
    2,888
    check the linkage for the IMRC. if the bracket connecting the two sets of butterflies isnt connected, that cable can pull on nothing all day long
    R.I.P. CSVT "clockwork" totaled 10/29/10 n/a 3L 220whp 212 trq
    I had similar behavior and it turned out the grommet that attached the IMRC relay arm to the front secondaries (radiator side) was broken off, so when the IMRC would actuate it was only on half the cyl and gave a less then satisfactory burble, the interesting thing to note is that there was no cell code either.
    good luck...
    2004 Volvo V70 T5 Manual // 1999 Black/Tan CSVT #2658 of 2760 // 1989 Yamaha FZR600
    Feb 2007
    Edmonton, Alberta, Canada
    80
    Quote Originally Posted by gooserex View Post
    good luck...
    That's exactly what happened to me. The engine had no low end power at all, but would pull normally above 3800rpm. I found that the butterfly valves for the front three cylinders were wide open the whole time.
    May 2006
    Sunny San Diego California
    249
    Intermittent IMRC behavior points to a transistor on its way out.
    A worn transistor operates normally at colder temperatures but can overheat and cause your secondaries not to open. After the car is nice and hot, open the hood and rev it up to see if the cable moves. If it doesn’t, that is your problem.
    1998 CSVT 184 WHP/175 WTQ 233 WHP/215 WTQ w/Nitrous 75 shot
    2005 Nissan Titan 305 HP stock
    2002 Subaru WRX E85 356 WHP 345 WTQ (RR self tuned) EVO III 16G
    2004 C5 Z06 Corvette
    1988 RX-7 Turbo II (FC) Streetport 297 WHP/272 TQ SOLD
    May 2004
    Coon Rapids, MN
    5,296
    Quote Originally Posted by allstyle12 View Post
    Well I wouldn't say that is the case all of the time, because it sure wasn't in my case.
    Early 98 Contours and a few mid 98 Contours have been known to have the same wiring harness failures as the recall for the pre98 Contiques (99M03 I believe?) In anycase for me I had the insulation breaking off of the wires going to my IMRC box. This causes some of the wires to short together intermittently, which causes my IMRC box to open/close at random. This was all burried under looming and was not visible until I took it off.
    It wouldn't hurt to check your wiring going to the IRMC box as well for cracked/exposed wires.
    -Mike
    98 SVT Contour - HoK TruBlue|CF roof|#49/6535 DOB 3/25/97|550whp here I come|Follow my extremely slow 3L/turbo build here Link
    85 Camaro - 1969 350ci, 503BHP
    05 Ford Expedition Eddie Bauer Edition - Every option
  9. #9
    Word. My IMRC used to work once or twice before the car warmed up then nothing. Didnt work at all over 80*. My solution was buying a brand new box after a failed transistor repair. I got it from Steve at Tousley Ford for 140 shipped to my door in 2 days. Haven't had a problem with it since. If you search, I did a nice write up on how to replace it.
    2013 Dodge Dart 1.4T/6mt
    Viper powered project with father
    99SE 142.5dB traded in 04/13
Similar Threads
  1. Before you replace your IMRC or the IMRC transistor
    By xtascox in forum Duratec Maintenance
    Last Post: 04-26-2011, 10:44 AM
  2. Basic tuning overview
    By mtxcontourSVT in forum PCM Tuning
    Last Post: 03-21-2010, 12:36 PM
  3. IMRC stuck open by PCM
    By svtpimp in forum General Troubleshooting
    Last Post: 10-08-2009, 08:19 PM
  4. IMRC won't close, P1518, HELP!
    By sjones in forum Duratec Maintenance
    Last Post: 03-14-2009, 08:30 PM
  5. jeff's 3L swap done (port matched)
    By svt1480 in forum Duratec 3L
    Last Post: 11-06-2008, 12:57 AM
