I keep seeing mentions and references to it, but can't seem to find it.
Something about the silverstar 9005, and cutting tabs?
1995 Ford Contour Gl
2.0L
2.0L
get the lights and try plugging them into the low beam harness you will see what is being talked about .... iirc the 9006 lights have one alignment tab for the bulb and the 9005 have two, just remove on the light of the connector to make it plug in ....
- 12 Focus SE
- 95 Mystique LS <-sold
- 2k Contour SVT - #2137
ahhh, i see it...that looks like a real pain
hmm, well I have 3 Bulbs sitting in front of me
all Sylvania's
siverstar 9006 ST
(stock replacements) 9006 hb4
(stock replacements) 9005 hb3
the 9005 and the 9006 look similar, but the 9005 seems to have a smaller rubber seal, is that going to be a problem?
It's not really a pain at all - it's just taking an x-acto knife & shaving off a tab inside the socket of the lightbulb. Just do it ... takes a couple minutes .
~~~~~~~~ Allen ~~~~~~~~ALOHA everyone !!
Yep. really easy.
Former owner of a '96 Zetec and original owner of a '98 V6, but I couldn't afford to keep the V6 on the road (well either one really).
Now trolling in a '98 Jeep ZJ.
Yep, real easy. Had mine on for quite awhile now. Heres a pic on my Cardomain page.
1995 Contour GL, Zetec, ATX, 118k - Sold
2012 Mitsubishi Lancer GT, 2.4L, CVT and it begins again.
i had some 80Watt 9006 bulb on there and well i they still sucked. i put crappy 9005s in and holly crap! i got good lights now. i did have to re-aim my leadlamps.
-Jon
99 SVT Contour T-Red. #2437
www.myspace.com/ripscottfrost
I used a dremel with a flat ended carbide bit. About 5-10 seconds of shavings per bulb.
morbid
2011 Edge SEL AWD (black) - daily driver
2000 Contour SVT (black); #61 (Sept 17, 1999)
3L with ADC turbo kit; 325hp / 338tq @ 7psi
car is down with a broken tranny
I just re-wired mine with 9005 heavy duty sockets since I'd heard of sockets/harnesses melting.
Ohsigmachi
Old ride: '96 GL MTX Zetec **sold after ten years of ultra-relible service.**
Newest Ride: 2003 Jaguar S-type R = Superchraged Luxo-rocket
--I don't want to hurt you, but it's still on my to do list.--
Ok, so I've said it before on the old forums and I confirmed it again last night. There is NO need at all to cut the tabs on the bulbs to get a 9005 into a 9006 socket. Wiggle it around, drop a couple tabs in first, rotate, then the other will slip in. I don't know why everyone is cutting.![]()
1998 SVT Contour 3L (B/MNB) #542 (His)
2000 SVT Contour (SF/MNB) #1533 (Hers)
2003 BMW 540i M-Sport (6 spd)
2002 Cougar XR - XR Racing Red
2002 Lexus IS300 SOLD!!
