Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 21
Thread: Tell Me About Your Exhausts
    Nov 2004
    Villa Park, IL
    896
    Default Tell Me About Your Exhausts
    I am interested to hear how different turbo setups are running their exhausts. Such as size, brand, material, cat/no cat, any type of resonator, what brand and style of muffler(s).
    Mine is as such...
    3" stainless steel downpipe> to ADC Cat> to a single inlet camero style magnaflow muffler> duel stainless tips
    Mine has a bit of exhaust induced vibration at a few different RPM ranges and I am hoping that the addition of a 3" straight thru magnaflow muffler will tame it a bit. Thoughts?
    -Adam-
    00' CSVT #0939 - 46K - 05' 3.0T - 17k
    GT3076R @ 8 psi
    Repairs / Installs? Yep, I do that.
    Sep 2000
    Louisville, Ky
    9,565
    Mine is the the supplied SS 3" downpipe w/ no cat, 3" aluminized exhaust routed straight back underneath the gas tank, then splits to quasi dual with 2.25" piping for each and Magnaflow mufflers.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    Nov 2000
    The land of Vegemite and Foster's (Actually Livonia, MI)
    10,298
    Add a resonator, Adam.
    PM me for Bendix Brakes Kits!
    SVT Mesh Grill Kits $80
    Your knuckle rebuilt w/new bearing $55
    AUSSIE ENDLINKS $75
    Gutted pre-cats $80/set, AC Condenser $50, SVT Heads $150/pair (no cams)
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Quote Originally Posted by Stazi View Post
    Agreed.
    10
    Nov 2004
    Villa Park, IL
    896
    Resonator it is! Stazi, this was your exhaust at one time correct? I got it from Scott with the turbo kit. What are you running currently?
    -Adam-
    GT3076R @ 8 psi
    Nov 2000
    10,298
    Yep I built it myself.
    AUSSIE ENDLINKS $75
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by Tony2005 View Post
    Rather than sending him/her a virus, I'm sure there is some interstate commerce law that he/she is violating that the admins can report him/her for. Interfering with interstate commerce or something like that. Where are our in house attorneys? We should let the feds deal with him/her.
    "Entiendo un poco espaņol"
    The "supplied" downpipe is only 2.5" folks!!! A 3" pipe will not fit. This is why a better idea is to vent the wastegate instead of plumbing it back into the undersized down pipe. The highest HP Contour to date so far uses this exact setup. No forged internals either. hmmm...
    2000 SVT #674
    13.47 @ 102 - All Motor!
    2005 Magnum R/T
    2 Ton Tank with a Hemi
  9. #9
    notta Demonsvt I have it plumbed back into the downpipe if you are talking about the highest HP Tour here. You will soon find out if that even comes into a problem because I will be dynoning soon with more boost pressures. I think it will make the curves a little different but I think you can still push 600hp through a 2.5 pipe it just will have a little back pressure.
    Oh I am forged totally too not that it matters.
    www.nautilusperformance.com
    99 SVT #198 blk/blue
    Spec 3/quaife/stage 2 shafts
    T3/T4 60-1 fully built 3.0 liter
    oval ported heads
    400whp 410wtq 13 psi
    13.2 @ 107 mph
    clifford alarm and turbo timer
    koni struts H&R springs
  10. #10
    Apr 2002
    Durka Durkastan
    3,003
    Quote Originally Posted by DemonSVT View Post
    I can't really think of a case where it would actually be bette to plumb the wastegate back into the downpipe.. no matter the size.
    It's only loud when you get on it anyway.
    04 Subaru WRX - 13.08 @ 106.55 Corn Powered
    SZ Top Troll '06 & '07
    SZ Fastest CEG'er '06 & '07
