I have a high powered Panasonic HU that is producing 31 watts rms per channel and any time that I turn the volume up over 3/4 of the way I blow my interior light fuse. Why this fuse and not the radio's fuse. I have correctly connected everything and have double checked the connections as well. I have bypassed the factory amp so I know that it is not causing this. The HU itself has a 15A fuse while the fuse that continues to blow is only 7.5A. Is it safe to put a larger fuse in its location? Should I run the power source wires to a different fuse that is rated higher and if I do will it cause to much strain on it. Any help would be great.
