Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: winter door problems
  1. Default winter door problems
    Does anyone here live in an area where the temp will get below zero is the winter? Usually when it does around here my door will not shut. the locking mechanism will freeze stuck. meaning I pretty much have to drive around holding the door.
    My plan is to take the door apart and just lube the hell out of everything any other ideas?
    98 contour 2.0
    Jun 2005
    Virginia, USA
    11,070
    "Does anyone here live in an area where the temp will get below zero is the winter?"
    Used to.
    "My plan is to take the door apart and just lube the hell out of everything any other ideas?"
    I used to just spray the locking mechanism with WD40 without taking apart the door.
    "Entiendo un poco espaņol"
  3. Default
    tried that last year and got nothing. i'm thinking i need some dense grease
    98 contour 2.0
    Jul 2004
    Wisconsin
    2,235
    yea, here in wisconsin...
    The problems I've had with the weather are usually not being able to open the door because it freezes shut. It's happened time and time again, even when I put some sort of a lube on the door seal. Last year I had the same problem you did, I wound up driving the car into the garage and using a hairdryer oon the lock mechanism for a couple minutes and it wound up shutting. YOU ARE NOT ALONE! hehe
    2000 Contour SVT
    SF - #542 of 2150
    3L: SVT Cams/LIM/UIM/Optimized TB/MAF
    HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
    Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
    Tuning: Xcal2 with PRP
    Susp: Bat Euro Kit
  5. Default
    sounds like it needs to be some sort of recall, i wish
    98 contour 2.0
    Aug 2001
    Waterbury,CT
    4,847
    yep and i have to hold the door closed while i'm driving until the interior of the car warms up enough to warm the door, then it will close and latch properly.
    Hugo 99 contour svt #1750/2760
    my profile
    some pics
  7. Default
    very lame huh
    98 contour 2.0
    Dec 2004
    Springfield, Ma
    878
    definetly not alone.
    door wont catch for a while. especially sucks if the car is being parked and the door wont close
    - 98 SVT #5999 -.
  9. #9
    Apr 2005
    Pillaging in Freedom, PA.
    3,875
    I use a rope & tie it to the other door. Once heater gets going, the door ill catch, then I hide the rope till next time. I've tried grease, no success.
    Scott,
    1999 CSVT, Tropic Green, #2068
    "And that was all without even a single drop of rum" -Captain Jack Sparrow.
    If I'm a moderator, why don't I have groupies!?!
  10. #10
    Dec 2003
    Hub City, TX and the Dirty Glove state
    1,700
    Happens to me every winter I've been at college. Since I have to park my car outside. It also usually freezes when I go up to the library and leave it outside in the night till early morning. I always use a methanol-based de-icer. I bet it's horrible for the paint, but when you're groggy at 3am from reading all night and are standing outside freezing, it's the best method! I can't imagine why wd-40 wouldn't work for you. I'd imagine you would have to spray a bit more than a dedicated de-icer, but nonetheless it should work.
    Try a dedicated de-icer though. They're relatively cheap, and I'm still using the same can from four years ago. Now spraying this on the actual door latch may not be a good idea. I usually spray this stuff in-between the weathering strip where water gets in-between and hardens making the door stuck to the body.
    99 Black Contour SE Sport
    "I left Detroit, but Detroit has not left me."
