+ Reply to Thread
Page 3 of 4
FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 32
Thread: removing McGard (Ford) wheel locks with no key
  1. #21
    Join Date
    Sep 2002
    Fox Lake, WI
    Posts
    14,148
    Default
    See:
    *CLICK HERE ---> 1995 SE 3L WITH MATCHING TRAILER <--- CLICK HERE*
    23 Contour / Mystiques and counting......
  2. #22
    Join Date
    May 2007
    pig's eye, land'o'lakes
    Posts
    131
    Default
    Couldn't it just be cut off w/ a cutting wheel?
    '99 SVT#2062 SilFro/MNB moded some
  3. #23
    Join Date
    Dec 2001
    Gales Ferry, CT
    Posts
    24,502
    Blog Entries
    93
    Default
    Quote Originally Posted by dubsac2 View Post
    i would say good luck with that without damaging the wheel and/or the stud
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- trading in 2/11
    - 99 Contour SeVT <- 3L/NPG Turbo
    - 2k Contour SVT - #2137
  4. #24
    Join Date
    Sep 2002
    Fox Lake, WI
    Posts
    14,148
    Default
    By that post, you clearly don't understand the situation and the options you have to remove the nut without damaging the wheel or stud.
    The nut doesn't stick out past the face of the wheel so what are you going to cut with a cutoff wheel? If you ground the head off the back of the wheel stud and tried to hamer it through to the front you would be doing a lot of work and I think you still wouldn't be able to get it out because the holes for the wheel studs are pitched.
    Hammering the socket on is the easiest, quickest way to do it, and it worked for both McGard nuts I had to remove.
  5. #25
    Join Date
    Mar 2007
    South Amherst, MA
    Posts
    6,054
    Blog Entries
    7
    Default
    I smashed an 11/16 socket onto a stock lugnut because it was rounded.
    Ian
    2012 Hyundai Accent hatchback
    1996 Zetec ATX - Retired but still running (barely)
    Aircougar Performance
  6. #26
    Join Date
    Sep 2002
    Fox Lake, WI
    Posts
    14,148
    Default
    Nice! This turned out to be a good thread.
  7. #27
    Join Date
    Feb 2009
    SEMO
    Posts
    634
    Default
    Quote Originally Posted by blu_fuz View Post
    Since we are in this thread because it was bumped..... You can remove mcguard lug nuts with a 13/16 socket. I have done it twice. Hammer that ••••• on trying not to mess up the hole the socket wrench goes into. You only get one chance with each socket . I even kept the lug with the socket whammered onto it.
    x's 2 on this. when i bought my SHO it didn't come with a key for the locking lug nut, it did however come with 4 bald tires. i searched everywhere for a key and no one had one due to the age of the car. i contacted mcguard directly and the rep was a prick and told me it was gonna cost roughly 50 bucks to get a new key. i said screw that went to napa and got an impact socket (i forget which size), cost like 15 bucks and hammered it on. worked for all 4 locks and still works fine as a socket. to get the nut out of the socket i simply threaded an old lug bolt through the back of the socket into the nut and smacked it a couple of times with a hammer. the nut pops out you take out the bolt and presto, you throw those piece of crap locking lug nuts away. it's pretty much faster and easier than welding, gluing, cutting or anything else you can think of.
    Green on Black '93 SHO 3.0 MTX *SOLD*
    T Red '98 Contour SE (Zetec)
  8. #28
    Join Date
    May 2007
    Posts
    131
    Default
    You are correct on that. I use a different type of bolt all together on my wheels. Never used ones w/ locks or ones that needed sockets. I use the dimpled round ones. But I assume everything can be cut off, and that is why I asked.
  9. #29
    Join Date
    Sep 2002
    Fox Lake, WI
    Posts
    14,148
    Default
    No prob - atleast we could clear that up for anyone thinking the same thing.
  10. #30
    Default
    Well, I figured the socket would slip since I do pretty much torque those things on to stay. We have specialty sockets to remove those lugs at O'Reilly, but everybody brings them back saying they don't work.
    2 year old thread indeed. It'll be priceless to anyone who needs it.................
+ Reply to Thread
Page 3 of 4
Similar Threads
  1. Ford takes $18 billion loan
    By svt4stv in forum Common Interests
    Last Post: 07-30-2008, 01:21 AM
  2. someone should email this to Clarkson
    Last Post: 01-02-2007, 06:21 PM
  3. Fun Ford History
    By AliasJerk in forum General Discussions
    Last Post: 10-11-2006, 06:33 PM
  4. Ford Iosis X "Concept"
    By todras in forum Pics and Videos
    Last Post: 09-29-2006, 06:13 PM
  5. Zetec Origin/History
    By hectik1 in forum Zetec Performance
    Last Post: 09-05-2006, 08:06 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
