i need help
i need help the ******* (sorry i am really angry)of my mechanic made the repair of my trainy and made a lots of mistakes the main problem is i run my trainy a full week withouth oil i noted because i found some kind of oil in the floor and i checked and find i dont have the drain plug installed i jacked the car and run under the car an see it, dont have the drain plug and neither the fill plug i recently repaired the trainy with new parts around 400 dlls money wasted for the bad mechanich i want to use the car when i shift thrif gear i ear a grindage then sometime the stick move itself to neutral then i shift to 4 and 5 and the same grindage i know the damage is there i cant do nothing to solve i only want to repair again with other mechanic right now i only want to add the royal purple oil and fill again anybody know wich plug i need to buy
the oem part number for the drill and fill plug?
or a autoxzone replacement number?
CSVT 98 #1862 of 6535 06/11/1997
3.0,tw8mm,msds-h,2.5exhaust ,optimized y pipe, superchip,original svt cams, unorthodox udp,stage 1 spec clutch,optima yellow battery
GTP 2002 no cat,original intake,mil eliminator,u bend deleted, 9.60 1/8 mille stock
