i can here a rumbling noise on the front right wheel. i can feel alittle on the pedal. could this be sway bar linkage? i havent looked yet it's been wet outside. it's been like this for a yr. also i think it can be the rotors.
1995 Contour GL Zetec with 116k miles.
1999 Ford Contour SE Zetec with 145k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
WANTED...
7 spoke SE rim center caps for a 95. PM me if you got one.
WANTED...
I didnt know you could feel it in the pedal! Ya wheel bearing or pads/rotors.
1998 #5979 SF/MNB
2000 #0801 B/T
BUY MY STUFF IN THE CLASSIFIEDS!!!!!
is it the piston grinding into the rotor?
230.2 WHP @ 6500
237.0 WTR @ 2250
99 Tropic Green SVT
no i just here a rumbling noise
WANTED...
happened to me to. wheel shook when braking. replaced the rotors and pads and went away. i wouldnt take a trip with those brakes if i were you. only takes about 25 min. to change brakes
98 SVT E0 Black/MNB #1756
98 SVT E1 Silfro/MNB #4852
mine did the same thing, it was the wheel bearing. one way to make sure that's the problem is to turn slightly left and right while driving straight (dont go off the road) and at some point you will hear and possibly feel a grinding noise. if you dont hear that, make sure your caliper mounts are tight, and that your brake pads are not worn out....
98 CSVT-black. on it's second 3L swap. 219hp/211 trq
