Hi, I hope that someone can help me determine what the issue is. My passenger side wheel rubs when I turn my wheel all the way to the right (hard right) to park or a U turn. I am unsure what is causing the rubbing. The size of the tires are 205/60R15 and it is the correct size. My driver side doesn't rub on a hard right or left. Any thoughts why it is rubbing? 2000 SE V6 Contour. Also, if I turn my steering wheel all the way left or right, I hear a sharp noise which sound somewhat like a grinding noise. What could that be. It's a different grinding noise compared to if you accidentally grind while shifting. It's not as forceful and a constant noise. Please help me. Thank you.
