Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: Dome light doesnt' turn on when door is open
    Aug 2008
    Belle Vernon, PA
    19
    Default Dome light doesnt' turn on when door is open
    OK a couple of days ago something weird happened.
    Ever since I owned my car my dome light wouldnt' turn on when I opened my driver's side door...
    But it was a morning shift at work...and the dang thing worked!
    But I had to move my car a little later and the thing went back to being broke.
    I went to a garage and found out a long time ago it was some wiring thing (it handles the security system and a few other things on tthe driver's side of the car)
    They told me it would almost $75 to order the part and about $56 to install it.
    Looking at what happened a few days ago... it sounds like this could be fixed without the replacement thing.
    any ideas?
    Jul 2008
    Juneau, AK
    1,007
    Are you sure it's not the door switch plunger? Mine was canted and worn. Replaced it and my dome lights work fine every time. So I scrounged a dozen from the salvage yard to stock away.
    1998 Contour GL 2.0L Daily Driver
    1998 Contour SE 2.0L Gave to daughter.
    Pain heals, chicks dig scars, glory...lasts forever....
    Aug 2008
    Belle Vernon, PA
    19
    OK I found the part that they said was bad.
    It's the "Ceneral Timer Module"
    Aug 2008
    Belle Vernon, PA
    19
    Me and my dad took the switch apart ourselves. Tested it with a multimeter. Works just fine.
    It was the first thing we through it was cause it looked a little rusted. But for all intents and purposes it "works".
    Sep 2002
    St. Louis, MO
    2,828
    1. Identify your vechile.
    2. Have you checked the position of the switch on the overhead console? If in the "wrong" position, it disables your interior dome lights when the door is opened. See your owner's manual.
    Steve
    Owner's manual for 1996 and newer are available to download from www.fleet.ford.com under MAINTENANCE tab.
    98 Contour SE Sport 2.5 Duratec ATX - 197K
    2001 F250 Super Duty 6.8L 4x4 - The NEW Workhorse 152K.
    2007 Mariner 3.0L AWD - Wifey's new ride.
    Aug 2008
    Belle Vernon, PA
    19
    1999 Ford Contour Sport
    and what do you mean "over head console"? Cause there are only 2 switches on it, which isn't really a "console" and only turns on the "reading" lights.
    Only the drivers door doesn't cause the dome light to go on. The other 3 doors, when opened, have the dome light go on.
    Jul 2008
    Juneau, AK
    1,007
    Quote Originally Posted by Namrepus221 View Post
    Try swapping a door switch from a door that does work to the one that doesn't. If it works, it's the switch. But if it doesn't, it's the wiring. Verify by putting the bad switch into a door that used to work.
    Quote Originally Posted by Scorpion8 View Post
    Correct. Most times it is the door plunger switch.
  9. #9
    Sep 2002
    St. Louis, MO
    2,828
    In my 98, the overhead map light assembly, in addition to the two map lights and their respective switches, has a switch in the center of the assembly that controls the behavior of the dome light.
    Since it is now known you have the 99, you likely don't have this feature unless you have a sunroof.
    Steve
  10. #10
    Aug 2008
    Belle Vernon, PA
    19
    We've tested the plunger using a multimeter, but we can always try it again.
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Basic tuning overview
    By mtxcontourSVT in forum PCM Tuning
    Last Post: 03-21-2010, 12:36 PM
  2. Problems with light - Quite long!
    By TGO in forum Common Interests
    Last Post: 04-05-2007, 08:02 PM
  3. No dome light when drivers door open
    By amsra in forum General Troubleshooting
    Last Post: 03-01-2007, 06:14 PM
  4. Battery light flickers at idle
    By bonsai in forum General Troubleshooting
    Last Post: 11-12-2006, 03:48 PM
  5. GM style DRLs?
    By Big Daddy Kane in forum General Mods
    Last Post: 10-24-2006, 11:22 PM
