Results 1 to 9 of 9
Thread: Another question, already searched for this one...........
    Feb 2008
    St. Louis, MO
    131
    Default Another question, already searched for this one...........
    I have a 98+ zetec, and all I ever see is ATX's, I don'[t think I've seen anybody with "98 MTX" in their sig or anything. First, did 98+s come with MTXs ever? If they did, would a swap be that hard from ATX? Wouldn't you just have to get the transmission monted, and switch to a 98+ PCM for MTX. IF they didn't ever come with MTXs, then how much harder would it be to swap in a pre98 MTX, I know the PCMs will be different because of the valve system differences between the years, but would there be any way around that? Would mystiques be any different, like did 98+ mistiques ever come in MTX?
    I'm asking becase I love the zetec platform, its fun to drive, but I would prefer a MTX. I'm very mechanincal, so is my step dad, and we have a family friend who is a mechanic, so I'm sure we could figure this out. I just want to know if its actually possible in the first place.
    1998-SE-Zetec-ATX-96,xxx
    Mar 2004
    Louisivlle Ky
    6,934
    Yes 98+ Zetecs did come with an MTX. in order to do an MTX swap you will need the subframe, PCM, trans, shifter and its base, shift cables, axles, and possibly the wiring harness
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Feb 2008
    St. Louis, MO
    131
    Really, well I might have to look into that once my auto gives out, which I know it will soon. I guess right now i should start saving up some money, maybe get s job or somethin.....
    Another part you'd need, guage cluster, cause of the tach.
    Mar 2004
    Louisivlle Ky
    6,934
    Tachs pretty much only came on mystiques and V6 Contours. the Contour Sport may have also come with a tach.
    Quote Originally Posted by striker2 View Post
    Contour sport did come with one. at least in 97
    JamesMason1
    2006 Fusion NPG V6 S/C Eaton MP90, 38# injectors, trans and aftercooler (10.5# boost)
    Your name is no longer on the prison cell, the cell door is open, so don't use it as a pantry for spices to stir a hot mess up in your life.
    Mar 2007
    Oakville, Ontario, Canada
    587
    Blog Entries
    3
    to answer your atx to mtx conversion question
    Quote Originally Posted by beyondloadedSE View Post
    Yup....you pick up a manual car and sell your automatic contour because its cheaper than doing the swap.
    MTX75 Transmission $1600?new $~700used
    Clutch Disc $100.21 Plate $103.20 F7RZ-7550-AA & F7RZ-7563-AA
    Clutch Slave cylinder $73.84
    Flywheel $94.48
    Left half shaft $150?
    Right jack shaft $50?
    Clutch Master Cylinder $29.19
    Clutch Pedal Assembly $178.62 F7RZ-2455-AA
    Clutch Hydraulic line upper $15
    Clutch Hydraulic line lower $15
    Clutch fluid supply line $5
    Mount-fender side $85.22
    Mount-tranny side-left $41.25
    Mount-tranny side-right $40
    Mount-cross member side-right $36.97
    Shift Tower Assembly $72.97 XS8Z-7210-BB
    Shift boot $29 regular $99 leather
    Bolts- Clutch to flywheel $2
    Friction Modifier $3.60 XL-3
    Crossmember $450
    Shift cables $45
    3 quarts Mobil 1 synthetic ATF $15
    Vehicle Speed Sensor-mtx $50
    134Kohm resistor $1 Radio Shack
    or just buy a donor car and swap everything over
    IIRC, 4 banger cougar MTX transmissions work with our cars too
    good luck!
    I used to rock a 1998 Contour, Silfro Betty will be missed
    New ride
    2005 Saab(aru) 9-2x Linear, 5MT, unmolested for now, just changed cabin filters!
    Mar 2007
    South Amherst, MA
    6,054
    Blog Entries
    7
    Quote Originally Posted by alex894 View Post
    Yup, but good like finding one! Those are even more uncommon than MTX Contours! The funds just aren't worth it unless you find a CHEAPPP parts car.
    Ian
    2012 Hyundai Accent hatchback
    1996 Zetec ATX - Retired but still running (barely)
    Aircougar Performance
    Quote Originally Posted by zorrex View Post
    most of the 4 cyl cougars were mtx, only 500 or so were atx, over the past 4 years only 3 or 4 have showed up on newcougar including mine.
  9. #9
    Mar 2007
    South Amherst, MA
    6,054
    Blog Entries
    7
    That's not the point. Most Cougar's were V6.
    Ian
Similar Threads
  1. sidemarker question
    By BAD SVT in forum Lighting
    Last Post: 08-01-2008, 10:44 AM
  2. Question...question...question.
    By Nerawkas in forum Exterior
    Last Post: 06-01-2008, 12:43 PM
  3. LCA question and rear suspension
    By tigerbalm in forum Suspension
    Last Post: 04-30-2008, 04:35 PM
  4. Question for the well-seasoned vets out there
    By Klasse Act in forum Auto-X and Open Track
    Last Post: 12-06-2007, 03:25 PM
  5. dumb question: i searched:!
    By TRicker in forum Duratec 3L
    Last Post: 06-08-2007, 03:06 PM
