I've got a 2-5/8" oil pressure gauge installed in my custom dash pod and i'm adding a pillar pod this winter. I'm thinking of adding:
Water temp
Oil Temp
Volts
Good choices? Suggestions?
~Josh
Water temp
Oil Temp
Volts
~Josh
99 SE "BLKOUT" - V6/5spd - 156 HP\157 TQ 15.166-90.84 / 99 SVT "BLKOUT2" - # 1571 - 184 HP\166 TQ 14.999-91.88 / 98 SVT "FREESVT" - # 4462 - Track whore under construction / 99 SVT "GINGER" - # 875 - DD Beater / 98 SVT - #3318 - 3L
sound like good picks to me, I am going to try my own dual gage bezel and I want to add oil temp and I am not sure what else, maybe coolant temp also ...
If i get the tuning software this winter i'm planning on i'm going to probably cut the volts gauge and install a wideband O2 in it's place.
~Josh
Mazda North America Sales (K.C. Mo.)
Buy Mazdas From me!!! Think: MazdaSpeed
E0 3l--13's **Parting Out**
2000 SEVT-- The Pretty Car (Work in further Progress)
Skip the volts and go straight to the wideband. Why spend money, if you know it's just coming out in the spring? That's just my opinion though!
Mark
2004 Mazda 6
Needs a Boost gauge![]()
230.2 WHP @ 6500
237.0 WTR @ 2250
99 Tropic Green SVT
If you need a volt gauge... and need a radar detector, the Escort 8500 x50 has a display mode where it'll show voltage when there are no alerts. You won't hog up a gauge port for voltage then.
morbid
2000 Contour SVT (black)
#61 (Sept 17, 1999)
