Page 1 of 2
1 2 LastLast
Results 1 to 10 of 20
Thread: how long did the factory...
    Default how long did the factory...
    water pump last for you? I have 142k miles on my original one. Just wanted to see how long it lasted for you guys. I'm sure theres people here with more miles than mine.
    1995 Contour GL Zetec with 116k miles.
    1999 Ford Contour SE Zetec with 145k miles.
    AIM Name: ContourAlf
    Yahoo IM: Contour_Freak
    WANTED...
    7 spoke SE rim center caps for a 95. PM me if you got one.
  2. Default
    About 81K and that nasty plastic impeller disintegrated.
    Not having any coolant moving around in your aluminum block engine isn't a good thing...
    And the roll restrictors (motor mounts) were shot at the same time.
    This is a 2.5 SVT though
    Quote Originally Posted by Winky3 View Post
    im not sure if mine has the plastic impeller.
    WANTED...
    Dec 2001
    Enfield, CT
    20,538
    Blog Entries
    93
    this has been posted before, the zetec doesn't have waterpump failures like the duratec ... plus it is like a tradiational waterpump and has a weep hole so you can check it that way ....
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    oh cool B-)
    WANTED...
    Dec 2001
    Enfield, CT
    20,538
    Blog Entries
    93
    btw I have 178k on my original to my knowledge ... knock on wood ... Unless you have no confidence in your car getting you home I wouldn't worry about something like this until a) it fails or b) your chaning the timing belt and can get to it easy and want peace of mind ...
    - 95 Mystique LS
    Mar 2004
    Louisivlle Ky
    5,202
    i had 230,000 miles on mine. finally started leaking. just changed it about 3 weeks ago.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
    On mine about 60k.
    '98 Contour GL Pacific Green(Modified)
    http://www.cardomain.com/ride/676416
    http://www.retrojunk.com/- Remembering the past!
  9. #9
    mines good it's not over heating. needle is alittle away from the middle
    WANTED...
  10. #10
    thank god my water pump doesnt run with the timing belt.
    WANTED...
