Results 1 to 4 of 4
Thread: Pre Upgrade to 3L
    Default Pre Upgrade to 3L
    I've been reading the 3L section of the forums and looking at users rides and decideing on a 3L upgrade. I want to know everything I can before I start though, so I don't get started and end up being, oh crap, now what do I do. I want to be working on it and be like, now I know this goes here because otherwise it won't work, and this little trick here gets this done quicker and easier than some other method, etc, etc. I still have a lot of questions though that I still need answered if anyone could help.... Like,
    When upgrading to the 3L what exactly do you take off the SVT motor and swap into the 3L? (Is it just the cams, oil pan, and some other parts?)
    Does this vary by which motor you choose?
    Which 3L motors are acceptable(like 99+ sable, xx year Taurus, etc,etc)
    Do all connections from the 2.5 motor match the 3.L motor, or does it vary by the year or model of vehicle you pull it from? Then if they don't match, are there adapters you can get so they will work?
    Is it a good idea to get the engine wiring from the 3L?
    Can you use the SVT pistons in a 3L block?
    1999 CSVT #1745 of 2760 T-Green/P-Tan
    DD
    Viper 791XV & Res Delete
    1999 CSVT #1831 of 2760 T-Green/P-Tan
    Project Car
    GS Autotech [MECP Cert]
    Pictures (finished)
    Rebuild Pictures
    Aug 2002
    Ottawa, Ontario
    1,547
    First of all it all depends on which flavor of the 3L swap you wanted to do?
    You can't use the 2.5 pistons since the 3.0 pistons are bigger...
    I would go with an 01+ preferably 03/04 engines, either from Taurus, Tribute, Escape
    If you use an Escape/Tribute engine there is gonna be a less transfer of parts over since the front timing cover, oilpan could be reused off the escape engines
    What do you mean by connections? Sensors? If so oil pressure sensor might, knock sensor will have a different plug or it won't be there at all... Its a good idea to get the wiring just to have spares and if you wanted to change the injector/oilpressure/knocksensor plugs
    Is your car return or returnless?
    3.0 13.5@104 http://www.youtube.com/watch?v=tisIv-JstmE
    NEW 4 bolt control arms $105!
    NEW GCK axles $65 each!
    PM me for details
    Jul 2004
    Wisconsin
    2,235
    All this info is here, repeated over and over...and over and over.
    Here's an example of a post with some info in it. Scroll down to my post for some info.
    http://www.contour.org/ubbthreads/sh...b=5&o=&fpart=1
    Oh and as far as wiring and sensors and stuff. Use all your Stock stuff.
    2000 Contour SVT
    SF - #542 of 2150
    3L: SVT Cams/LIM/UIM/Optimized TB/MAF
    HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
    Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
    Tuning: Xcal2 with PRP
    Susp: Bat Euro Kit
    Basic 3L info is also on my web site FAQ and if you don't plan on modifying everything to work we also sell them ready to go. See my sig for the site.
    1999 3.0L Cougar Supercharged (10psi)
    2005.5 Audi S4 (340hp AWD winter beater... )
    Visit: http://www.3LDuratec.com for interest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, our Supercharger kit, or anything 3L related.
