Programming for new ignition switch?
From searching, it appears the guidance is that if you have to replace the ignition switch, you have to have a dealer flash the computer or the new keys if you have a 98.5 or newer. My key is currently stuck in the ignition, and I'm pretty sure I'll damage the ignition switch if I yank the key out so I want to be sure I know what I'll need to do if I yank and damage the ignition switch. According to 3 Ford parts departments, I have to buy a full new lockset - ignition switch, 2 door cylinders and trunk cylinder - nearly $300!
Any advice how to avoid this and just get the $80 autozone ignition switch and new PATS keys (yes, doors and trunk will not match but can get non PATS key copies for separate keys, like the old days when you had round key for doors and trunk and square key for ignition).
Thanks.
Steven
'98.5 SVT - all mine since 23 miles on the clock
DMD, K&N, Magnaflow res, TH tranny rebuild, Quaife, and other light mods
