Results 1 to 6 of 6
Thread: 20 mm or 19mm
    May 2006
    Glen Ellyn, IL
    2,456
    Default 20 mm or 19mm
    ok ive seen on some parts sites that they say the 99 svt has a 20 mm front swaybar, but i was always under the impression that it was a 19 mm. and it its 19 mm that means the 20mm bushings that came in my kit wont fit.
    -Jon
    99 SVT Contour T-Red. #2437
    www.myspace.com/ripscottfrost
    Sep 2000
    7,343
    The sales literature that i picked up when I bought my SVT says that the front is 19 mm and the rear is 18 mm. I believe that is correct for all years.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Jun 2000
    Hammertown, Canada
    613
    Lightbulb
    Quote Originally Posted by Big Jim View Post
    I've measured a no. of them plus ordered a new 1 from Ford. 19mm is correct for the front bar and 18mm is correct for the rr.
    96 SE with '01 3.0. Overbored 62mm throttle body, custom LIM, double honed SVT UIM, SVT cams, headers, custom Y pipe, custom mandrel bent SS 2.5" exhaust, Quaife, torque brace and custom frt & rr suspension.
    I make custom suspension parts.
    Jun 2000
    San Jose, CA
    3,646
    Early ('95-'96) SE's came with a 19mm bar IIRC.
    Suspension in those was deemed firmer than the C-SVT's.
    '06 Saab 9-3 Aero 6MT - Sedan -Chili Red
    '08 Saab 9-3 Aero 6AT - Convertible - Electric Blue
    Like stated the SVT uses a 1mm smaller bar (19mm) in the front.
    However the larger OEM rear bars (95-97 SE, all SVT, & the "19mm" OEM bar BAT sells) are the same. They measure 18.6mm. (give or take some powder coating) I guess it is just in who measured them and if they rounded up or down???
    The 95-97 SE's had "stiffer" springs then the SVT. The SVT's had better struts in either version. Quality aftermarket parts make it a moot point by now. Both great then, still great now...
    2000 SVT #674
    13.47 @ 102 - All Motor!
    2005 Magnum R/T
    2 Ton Tank with a Hemi
    May 2006
    Glen Ellyn, IL
    2,456
    removed due to me being retarted
    -Jon
