Results 1 to 2 of 2
Thread: need spring help
  1. Default need spring help
    i have a 98 se, and it seems to me that the svt's are lower to the ground than the se is right from ford so do the springs interchange? can i effectivly lower the car by going to autozone and getting new svt coils or should i just hit up eibach?
    Sep 2000
    7,343
    The SVT is not lower. It only looks lower because of the SVT ground effects package.
    The SVT uses the same springs as a 98 and newer stick shift V6 SE.
    Jim Johnson
    98 SVT
    03 Escape Limited
