Best cylinder heads
I know the issues but would like some opinions regarding the use of oval port 3.0 heads vs. 2.5 split port heads with 3.0 valves & seats. Believe the most common/easiest method is to use the 3.0 oval port heads. Better oil drain back, valves & seats already correctly sized and in place, etc. SVT heads have the advantage of being Extrude Honed. I am not considering the use of early 3.0 heads with the externally driven H2O pump.
Any one flow benched the 2 back to back?
96 SE with '01 3.0. Overbored 62mm throttle body, custom LIM, double honed SVT UIM, SVT cams, headers, custom Y pipe, custom mandrel bent SS 2.5" exhaust, Quaife, torque brace and custom frt & rr suspension.
I make custom suspension parts.
