Page 1 of 5
1 2 3 ... LastLast
Results 1 to 10 of 45
Thread: side markers A6's or BAT's
    Default side markers A6's or BAT's
    i have found an old post on the side markers, i wanna purchase a set, i wanna go with the ones from BAT (smoked ones) but a lot of ppl suggest to get the A6's . any other options left?
    "I'm better than great , I'm good" Joey from "Friends"
    born on 04/22/99 # 2002 out of 2760, RS-7 18 inch Enkeis, Dual Magnaflow KYB's + H&R's, Clarion + Kenwood Excelon KFC-X680 6x8"
    Aug 2000
    Bernalillo, NM
    8,460
    I got some from Summit and tinted them myself. I think they were ~$20.
    -Ken V.
    1998.5 SE Praire Tan Zetec ATX
    Roush springs - Roush sway bar - Bat struts - subframe connectors-Poly here and there - front and rear strut bars - Milli Miglia HT3 17" - SVT bumpers - SE skirts - Striker endlinks - Stazi mesh
    Dec 2001
    Enfield, CT
    20,471
    Blog Entries
    93
    well I just installed the A6 ones myself ... I wired them to be half bright all the time and full bring with the turn signals ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Oct 2005
    Toledo
    1,186
    I have the A6's and the previous owner of the car tinted them. Love the way they look.
    I need to figure out what Brapple did to get them working half bright as running lights, I've always wanted that
    Only pic I could find, and somehow they look round in that picture
    Screaming for a Mirko
    TRed CSVT on FSVTs.. in pieces for now!
    http://www.cardomain.com/ride/2154233
    Dec 2001
    Enfield, CT
    20,471
    Blog Entries
    93
    Quote Originally Posted by Berkel View Post
    why I followed the how to for the A6 side marker install ...
    - 95 Mystique LS
    Oct 2005
    Toledo
    1,186
    Oh I thought it only explained just how to get turn signals working. Thanks, I need to learn more about electrical anyways, I have no clue when it comes to this stuff
    Dec 2001
    Enfield, CT
    20,471
    Blog Entries
    93
    it really isn't to dificult, the light will have two wires so you need to leads for the light. One will be for a ground and one will be for power. as the little diagram showed in the how to you need to add a diode and a resistor on the power feed, I did this with in 1 ft of the headlight so only two wires run to the light. the one leg will have a ressitor connected to the constant power and the diode goes on the other leg to power the turn signal. since both the constant 12v and the turn signal are on the same wire that is where the diode comes into play, it prevents the constant 12v power from going back into the turnsignal circuit. it also let the power through one way so that the signal goes full bright when the turn signal is turned on. just get the listed items and wire it up and your good to go
    - 95 Mystique LS
    as simple as that but who onws the BAT ones?
  9. #9
    Can either of those be purchased at AZ/Oreilly's/Pep boys?
    I like to actually look at them first before I buy them.
    E0 #4384 of 6535
    Born Jan. 9 1998
    Purchased Nov. 2002 @ 76,559 miles----SOLD!!
    2001 Buick Century Custom, Factory Warranty
    1966 Mustang 302 bored .40 over w/Tremec 5 speed
    www.TexasStang.com
  10. #10
    Dec 2001
    Enfield, CT
    20,471
    Blog Entries
    93
    Quote Originally Posted by CSVT985 View Post
    which ones?
    the A6 ones come from Audi ...
    the Bat ones come from BAT ...
    and the other set pictured came from summit ....
    those placed would have some other type, like APC ones ...
    - 95 Mystique LS
