I busted the right rear wheel speed sensor and now the ABS light is on..
anyone know where I can get one and are they inerchangeable with other years / cars?
is it not part of the rear hub ?
I had to replace my front sensor as we cracked it when we removed and reinstalled a half shaft on my car.. Not 100% sure if it will be the same but if it was it took about 15-20 minutes... just unbolt and unclip and do the same with the new one.
Crispy
'02 VF34 2.0 Turbo Subaru WRX -- STAGE 2+
'05 M53 2.8 Turbo Jeep CRD --
See My PREVIOUS Rides
discount code...
520933476490 5% off - EXP 12/19/06
Crispy
just looked quick and we sell em at work... the discount code for RockAuto should be posted here in the forum so you can get 5% off.
1998 : FORD : CONTOUR SVT : 2.5L 2450cc 155 cubic inch V6 FI (G) : Brake/Wheel Hub : ABS Wheel Speed Sensor View Advice
STANDARD MOTOR PRODUCTS Part # ALS123
Left Front; Front $69.79
MOTORCRAFT Part # BRAB155
w/Sensor Wire; Front Right $84.79
w/Sensor Wire; Front Left $84.79
MOTORCRAFT Part # BRAB151
w/o Sensor Wire; Front Right $94.99
w/o Sensor Wire; Front Left $94.99
MOTORCRAFT Part # BRAB60
Rear Left $99.79
Rear Right $99.79
STANDARD MOTOR PRODUCTS Part # ALS118
Left Rear; Rear {LEFT REAR}
**Non-stock item--shipping delayed up to 2 business days** $89.79
Crispy
Its not a part of the hub, its like a 5 minute change.
230.2 WHP @ 6500
237.0 WTR @ 2250
99 Tropic Green SVT
oops just re read the post, i thought you meant the abs ring on the hub.
