Results 1 to 2 of 2
Thread: thanks
    Default thanks
    well i finally figured out how to remove cover on eec test ha ha .pulled codes176 and 543.thanks .from looking at threads the 543 could be ignored if car is running good.if the 176 gets worse will the cel stay on?the reason im asking is the light comes on for about 10 seconds every 2 days or so.i know just get the thing changed thanks again
    95 contour se 77000k electric red
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by mrstooge View Post
    ...if the 176 gets worse will the cel stay on?..
    Yes, unless the Fuse 11 holder is loose (or Fuse 11 is about to break).
    "Entiendo un poco espaņol"
