Results 1 to 7 of 7
Thread: underdrive pulleys
    Nov 2006
    Louisville kentucky
    60
    Default underdrive pulleys
    are the pulleys on the 2.5 the same as the 3.0
    pretty sure they are....someone back me up
    Aug 2002
    Ottawa, Ontario
    1,547
    Yes they are the same
    3.0 13.5@104 http://www.youtube.com/watch?v=tisIv-JstmE
    NEW 4 bolt control arms $105!
    NEW GCK axles $65 each!
    PM me for details
    Nov 2006
    Louisville kentucky
    60
    Default underdrive
    good looking out I didnt want to buy them for the 2.5 and then turn around and not be able to put them on the 3.0.thanx
    I hear bad things about them. Whatt's the life expectancy of the motor after these are installed? Also, what's a good brand?
    I have been debating on weather or not to buy myself a set.
    Sal
    Aug 2002
    Ottawa, Ontario
    1,547
    Underdriving the crank by removing the stock damper is not one of the best ideas
    PM me for details
    Lightbulb
    Quote Originally Posted by RAYSVT View Post
    Sometimes.
    To answer your question.
    Yes & No.
    The 3L uses multiple different dampers and pullies. Yes our, CDW-27, 2.5L damper/pulley works on the 3L engine.
    I don't recommend removing the stock damper. Yes some have done it without long term issues.
    2000 SVT #674
    13.47 @ 102 - All Motor!
    2005 Magnum R/T
    2 Ton Tank with a Hemi
