Results 1 to 6 of 6
Thread: Question
    Default Question
    has anyone bored a 3.0? I have a 3.0 block, bored .020 over and I need to find pistons, does anyone where to get pistons. I am actually trying to sell the block and the person I am trying to sell to wants to know what needs to be done, he thinks that you can get oversized rings. I just cant find any info anywhere.
    95 contour mtx 3.0L hybrid and new trans still in the works
    96 Mazda 626 2.0L Daily Driver
    Quote Originally Posted by BSOELMAN View Post
    Yeah their is someone on here that has a 1mm overbore (~.040").
    The ONLY 96 (engine) 3L - Dead at 12K miles
    Oval Port 3L with 1MM overbore and flowed/ported heads with all the other goodies.
    Those who can do. Those who can't teach.
    I have done it, but I have forged pistons ... Rock Auto has overbore pistons for the 3.0L.
    1999 Mercury Cougar - Turbo'd 3L.
    Status: Dyno number are in ...
    Power: 391.9 hp @ 6750 rpm | 374.2 lbs/ft. @ 4250 rpm | boost @ 11 psi
    For Sale: 19" Konig Verdicts with Toyo ProxesFZ4 225/35ZR19 Tires
    You can get stock overbore pistons through rockauto.com as mentioned or you can get custom pistons from some place like Diamond pistons. I wouldn't recommend going with a .040" overbore with the rockauto pistons because even though you can get the pistons because you have to order custom rings and have the pistons cut to the new ring thickness as well. Swazo and I learned this the hard way on the pistons for his engine. The pistons come with standard rings that don't have enough overlap in the size to be properly end gapped with a .040" overbored piston.
    Rick
    Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
    Buckshot77@msn.com
    Misc 3L parts for sale
    Forgot to add ... my overbore was .020", NOT .040"
    so there are regular, stock replacement pistons available and rings to match for a .020 overbore. thanks guys ill pass the word along
