Results 1 to 5 of 5
Thread: AC condenser
    Lightbulb AC condenser
    Has anybody taken out the AC,to relief some extra ponies from the car?just brainstorming and thought I would ask.thanxs!
    #985-Born:Jan-25-99
    SVT/SF....with to many mods
    '95 t-red mystique-sold
    May 2006
    Glen Ellyn, IL
    2,452
    or can you bi-pass the condenser with a shorter belt? i dont know i havent looked
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    yes some people have either bypassed the ac compressor by using the non-ac belt on the car and there are a few that have removed the sytem ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    You will not gain ANYTHING by bypassing the system.
    You will gain the equivalent of about 25lbs of dead weight if you remove the compressor and all hoses, etc. You could just as easily remove 25lbs of something else for the same savings.
    When installed, but not in use, the compressor clutch pulley freespins, so there is no drag, and no "waste" of horsepower.
    Turning the AC off is the same thing as bypassing it, with the small exception of the FRACTION of a horsepower of the freespinning pulley itself.
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    Ok so basically there is no difference if you take it off or not.Thats for the info guys!really appreciate it.
    #985-Born:Jan-25-99
