Results 1 to 3 of 3
Thread: direct trans swap bearing preload?
    Nov 2004
    Villa Park, IL
    896
    Default direct trans swap bearing preload?
    I am getting a used HMS trans with quaife. I have read countless times about the necessity for shimming and such when changing the differential. Now, I will NOT be opening the trans, just pulling it off of a blown motor and bolting it to mine. Is there any shimming or preloading that must be done or is that reserved for only when disturbing the differential within the case?
    Thanks.
    -Adam-
    00' CSVT #0939 - 46K - 05' 3.0T - 17k
    GT3076R @ 8 psi
    Repairs / Installs? Yep, I do that.
    you wont have to do anything. if you were to swap differentials, most fwd dont get shimmed. they just slip into place because of how they are set up. on rwd, thats different. you have to preload differential and pinion bearings. you have to dial it in within manufacturer specs so it has its best track, and depending on the use of it, noise.
    1997 Saturn SL2-project car (salvaged now, current tear down)
    1996 Ford Contour-DD, up and running again
    STC-OH member
    My SL2 and other cars
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Adam, I would hop over to FCO and contact Terry directly, I am sure he has a written history on that transmission and could suggest what is best to do
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
