tranny swap questions??
computer subframe transmission all clutch hardware wiring harness. Basically the whole front of the MTX car minus the motor. Cheaper to buy a new car.
using the search feature of these forums is awesome... you should give it a shot
Yup....you pick up a manual car and sell your automatic contour because its cheaper than doing the swap.
Lemme dig up the conversion list....
....Here we go...
MTX75 Transmission $1600?new $~700used
Clutch Disc $100.21 Plate $103.20 F7RZ-7550-AA & F7RZ-7563-AA
Clutch Slave cylinder $73.84
Flywheel $94.48
Left half shaft $150?
Right jack shaft $50?
Clutch Master Cylinder $29.19
Clutch Pedal Assembly $178.62 F7RZ-2455-AA
Clutch Hydraulic line upper $15
Clutch Hydraulic line lower $15
Clutch fluid supply line $5
Mount-fender side $85.22
Mount-tranny side-left $41.25
Mount-tranny side-right $40
Mount-cross member side-right $36.97
Shift Tower Assembly $72.97 XS8Z-7210-BB
Shift boot $29 regular $99 leather
Bolts- Clutch to flywheel $2
Friction Modifier $3.60 XL-3
Crossmember $450
Shift cables $45
3 quarts Mobil 1 synthetic ATF $15
Vehicle Speed Sensor-mtx $50
134Kohm resistor $1 Radio Shack
Have fun! :D
http://contour.org/ceg-vb/showpost.php?p=307477&postcount=2
