Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 21
Thread: Stupid question?
    Default Stupid question?
    I know this is really stupid, but the MSDS headers will bolt straight to the stock SVT exhaust right? I don't have to get anything else right?
    -Justin
    98 T-Red/Midnight Blue SVT
    Build # 3,585/6,535
    May 2006
    Glen Ellyn, IL
    2,456
    well yes but installing them is very labor intensive. also when you install them you should put on a MSDS or other y-pipe but yes they bolt to the stock y-pipe.
    as far as getting something else. your going to need new gaskets for your headers. MSDS comes with new studs and gaskets i believe.
    -Jon
    99 SVT Contour T-Red. #2437
    www.myspace.com/ripscottfrost
    Apr 2005
    Pillaging in Freedom, PA.
    3,932
    Yes, it bolts right up. I ran mine to the stock y-pipe with no problems, other than losing the ponies I will gain once I optimize it.
    Scott,
    1999 CSVT, Tropic Green, #2068
    Hotter than a $2 pistol.
    "And that was all without even a single drop of rum" -Captain Jack Sparrow.
    Sep 2000
    7,343
    And you will need MIL eliminators so you don't turn on the check engine light with cat failure codes.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Sep 2002
    Bradford, Ontario, Canada
    2,055
    dont you know its cool to have that light on?
    Wesley
    The Black Knight 1999 SVT #1870 RIP (parting it out)
    The Hearse 2005 Dodge Magnum r/t
    Jul 2004
    Michigan
    6,282
    Quote Originally Posted by 1FASTDAD View Post
    So is....mine......it has been on for 5 months. I just installed Joey's mil eliminators, and they threw a code in 5 days.
    FS:65mm Throttle bodies - SE TB - Zetec TB
    Never explain---your friends do not need it and your enemies will not believe you anyway.
    Oct 2007
    1,233
    I feel left out...Ive had MSDS headers on since jan, no MILs, no check engine light weird.
    If it's snowbird season, why cant we shoot em?
    Jul 2004
    Michigan
    6,282
    Quote Originally Posted by contourSVT99 View Post
    I've heard of that also on some other peoples cars. Your just plain lucky lol.
    Now if i can only fix my problem. Blah
  9. #9
    Can someone link a how-to on installing headers? I looked in the "how-to" section but only found something on how to optimize the y-pipe also did some searching with no luck. I know some veteran is going copy it in here and call me a newb but I am ok with that. Saturday is the day all my parts are going in and I am not worried about installing them, just want the write up incase I need to reference it.
    -Justin
    Build # 3,585/6,535
  10. #10
    Sep 2002
    2,055
    these are not quite how to's but propblems people had and answers on how to slove them.
    http://www.contour.org/ubbthreads/sh...ue#Post1198496
    http://www.contour.org/ubbthreads/sh...ue#Post1172272
    Wesley
