Locate the sender. Unplug it. Now, short the wire lead to ground and observe the guage. With the ignition switch in RUN, the guage should be pegged in the HOT direction. Unground the lead, the meter should be at rest it the COLD position.
If the needle acted properly, the sending unit is bad.
If the needle did not respond, the guage is defective or there is an open circuit in the wiring.
Steve
98 Contour SE Sport 2.5 Duratec ATX Was the wifey's car, now it's mine - 170K
89 Taurus SHO - Retired at 249K miles
94 SHO ATX - 240K
1997 F-150 5.4L E4OD - The Workhorse 170K.
2007 Mariner AWD - Wifey's new ride.
