Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: '98 2.0 won't start
  1. Cool '98 2.0 won't start
    The car died on the road,towed it to my friend's garage, hooked it up to his diagnostic machine and that gave me a code, P1838 which I found out, Thanks to this great forum I have just Joined, that the problem is the camshaft sensor.
    In the pursuit of fixing the problem we were checking the timing and we noticed on the crackshaft pully there is no mark to check against the oil pan. We have the right manul and we are winging it with the wrong hayens manual.
    I'm looking for a little help, ok a lot of help. Thanks
  2. Default
    Please help.
    There is no adjustment for timing on the 98 Zetec.
    You have to get it to TDC and align your cams and set tensioner.
  5. Default
    how do i get to TDC
    Remove the number one plug and you can stick a screwdriver down in the cylinder and turn the crank by hand until the piston gets to highest point. Are you sure that is the right code?
    The codes I am seeing online are, P1838 Transmission Transfer Case Shift Motor Circuit Failure
  8. Default
    Code P1383 indicates the cam is too far retarded during its “at-rest” position. The majority of the time when we see this code, it has set because the timing belt was installed incorrectly. Be sure to check the basics ... make sure the cams and crankshaft are in time.
    I got this from an ASE certified Ford analist
  9. Default
    sorry gave wrong code it's 1383
  10. #10
    Have you did a timing belt on the car?
