Results 1 to 6 of 6
Thread: Bassani Exhaust Silencer removal? HELP!
    Oct 2006
    Up North New Jersey
    1,813
    Default Bassani Exhaust Silencer removal? HELP!
    Having a bit of a problem removing the silencer inserts that come with the Bassani Exhaust Kit! Probably rust welded itself to the inside walls of the muffler tip.
    I lent these suckers to a friend and they pushed the silencer all the way into their exhaust and never screwed it where it was supposed to be screwed!
    I put some PB Blaster and Im gonna try to go at it tomorrow morning! But you really cannot get a grip on those suckers in any shape or form...
    Any suggestions or tools recommended to use to pull it out. I was thinking if there was some type of clamp that would be inserted in the middle and every click push out then against the walls of the silencer to make a grip and be able to pull it out!
    Without Silencers
    With Silencers
    As you can see there is nothing really to grab to pull the silencer out!
    - amyn
    99 (No Paint, No Powertrain, No Doors, No Trunk) CSVT - 0532
    Koni/GC's - 18" @ 15.2lbs - BAT 21mm RSB(Reinforced) - OMP/Rawburt STB - MSDS Headers to Bassani Catback - Ford Racing Wires - CF Trunk - Parkedcar Stamped - Samco Hosed - Baer BBK - 3L Turbo
    Nov 2007
    Astoria NYC
    874
    Post a pic with the silencers, so we can see what we are dealing with
    Oct 2006
    Up North New Jersey
    1,813
    Is there some type of clamp that will insert in the middle and with some sort of mechanism w/ every click push out into the walls of the silencer catching a grip/ handle to remove the silencer???
    - amyn
    Oct 2006
    Up North New Jersey
    1,813
    Torched a lil hole in it and popped a hook in there and it came right out!
    Hope it dsnt affect the sound of the exhaust!!!
    - amyn
    Jul 2004
    Michigan
    6,100
    Quote Originally Posted by qbcsvt View Post
    - amyn
    That was exactly what i was gonna recommend. It's the hot and cold that made the metal shrink to the point where they compressed into each other.
    Or do it while the exhaust was really hot
    I'm glad it worked out for you man.
    FS:65mm Throttle bodies - SE TB - Zetec TB
    Never explain---your friends do not need it and your enemies will not believe you anyway.
    May 2006
    Glen Ellyn, IL
    2,449
    make a vid so we can hear that sucker.
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
