offroadSVT
I just bought a 95 Contour to your for a DD and a break from driving my diesel everyday. When I bought the car, I knew there was an oil leak somewhere, but I thought it was the valve cover gasket since one end of the valvecover was covered in residue... so I put a new valvecover gasket on it and discovered another leak.
this one is below the exh manifold and above the oil pan gasket... basically right behind the cat where I can't see anything.
I bough the thing for $900 and just want to use it for running to work and back, but the leak is dripping right on the exhaust on the bottom of the cat, and I hate the smell of burning oil.
Any suggestions? Next week I'll going to pop the cat off (already started soaking the 4 bolts with PB blaster) and take a peak, but wouldnt mind a few pointers in advance
