Results 1 to 4 of 4
Thread: TB question
    Sep 2002
    Livin on Tulsa Time
    3,722
    Default TB question
    what all is required on the TB side of doing a 3L swap. I am doing a full 3L with the 3L lim, uim, and tb. what all do I need to be aware of
    STOCK HP IS NEVER ENOUGH
    Sep 2002
    Rochester, Minnesota
    3,860
    Not sure if you have an SVT or not, but I believe all you would need is the SVT TB cable/bracket if it's a non-SVT. If I understand correctly the 3L TB and SVT TB are the same.
    98.5 Se w/SVT mods - Revived!
    Sep 2000
    7,332
    They are not the same. The castings are the same, but the finished product is quite different. They are the same diameter.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Aug 2002
    Ottawa, Ontario
    1,547
    The newer taurus and escape TB's are not the same as the SVT tb or similar to it...
    It was the older TB's on the taurus's with metal UIM's which were the same casting
    You basically want to use the Taurus TB and mod the throttle body bracket so you can use your existing throttle cruise cables
    3.0 13.5@104 http://www.youtube.com/watch?v=tisIv-JstmE
    NEW 4 bolt control arms $105!
    NEW GCK axles $65 each!
    PM me for details
