1- The fuel flapper mod is not necessary if you aren't having fill issues. However, this doesn't mean you never will and if you have access to all the tools you'd need you might want to do it all at once. It is really up to you.
2- As the original thread states plainly, cutting dykes can be used to remove the tabs at the bottom of the tank. It is NOT recommended by Ford or any official "how to" but as long as you are careful and work in a well ventilated area then dykes SHOULD be fine.
3- You do have to cut your floor if you decide not to drop the tank so if you don't want to hack into your car then you have to drop the tank. I've done tank drops/pump changes on Mustangs before and it really isn't that difficult. On a Contour you do have to mess with the exhaust a bit but get the car on a lift or on jackstands and it shouldn't be very hard to do.
Lucky for me my 2000 SVT pump seems to be holding up nicely and no flapper issues yet, however I think I'm going to drop the tank when I do it because I am anal retentive and I KNOW with my luck I'd cut my floor, change the pump and promptly have flapper issues a month later...
-00' Contour SVT #1245 of 2150. Trubendz Borla exhaust, BAT Catted Y, Spec shifter, Injen CAI, NPG Big Brakes.
-95' Cobra SVT #3914 of 4005. Too much to list. 301whp/325wtq.
