Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: headers question...
    Default headers question...
    I've been looking at the headers information and on the MSDS site and it looks like the headers come with the y-pipe and piping to get it to the main cat.
    do the headers themselvs come to the same place that the stock precats come to? What i'm really asking is: will the headers be able to bolt up to the BAT Y-Pipe/Catalytic Converter?
    (sorry about the text, its part of the image)
    I'm asking because right now i have the BAT y-pipe but with a test pipe welded in place of the cat. My flex pipe is leaking and its cheaper to just buy a whole new kit from BAT. The reason i want a cat was that i'm planning on getting the Borla Cat-Back later on and i would need a cat in there to keep it from sounding too raspy. i was planning on doing headers too, but it looks like they wont bolt up to my BAT setup. On that note, is gutting the precats just as effective for increasing the sound as headers? (i'm not looking for huge performance gains... if i wanted that, i'd go with FI or 3L... but i'm happy with the power of my SVT... i just want it to sound better)
    ~Ryan
    1999 T-Red SVT Contour
    #1701 / 2760
    OZ Ultraleggera 17's, MSDS, BAT High Flow Cat & Y-pipe, B&M Short Throw, Taylor Thundervolts, Green filter, Pudmunkie heat shield, Audio
    They will bolt up to an aftermarket y-pipe.
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    they will bolt up to any y-pipe, I plan to use mine with my optimized stock y-pipe
    I would also look into the bat y-pipe more, people who have ahd similar setups or the same y-pipe set up loose torque ... you really need that bend on the one bank to build torque ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    problem is, i cant go back to stock because what i have now is a modified BAT setup. (sorry for the bad pics, they are old)
    closeup of the removed Cat
    ~Ryan
    #1701 / 2760
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Quote Originally Posted by Guitarman19853 View Post
    can't see the pics at work but I am sure you could find a used stock y-pipe, infact there is one in the classifieds now, used main cats may show up every so often or you can get a aftermarket high flow cat from trubenz I think it was
    - 95 Mystique LS
    Dec 2002
    Portland OR
    1,851
    That BAT y pipe is literally the same as the old SHO shop y. Not only should your MSDS headers bolt up to that BAT y pipe remainder you have, but if you later want to go back to a 2 inlet/1 outlet high flow cat, such products are out there as stand alone items.
    MSDS SHO-shop Y custom 2.5" catback; xcal2; 63mm TB K&N 3530 Pud heatshield; Koni struts Aussie bar; THaines forks Quaife SpecII UR fly; DMD; UD pullies; Pole120 mounts. 92.03 trap speed: Just a daily commuter. SF/MB '98 SVT E0 #3159 8/21/97 178K miles
    May 2006
    Glen Ellyn, IL
    2,452
    wait so your saying you get more power with the msds or opt. y-pipe than with the bat or true bendz???
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Quote Originally Posted by SVTJON87 View Post
    i don't know if it has been documented but I do remember reading that people felt less torque with a y-pipe design that didn't have the bend in it on the read bank
    also it is one of those things that hasn't been documented I believe but it has been said that a optimized stock y-pipe is better then the aftermarket ones ...
    remember sometime making everything larger, ie related to intake and exhaust isn't good and you will actually loose power ...
    - 95 Mystique LS
  9. #9
    May 2004
    Calgary, Alberta, Canada
    4,506
    Its negligable on our cars. Just go with whatever setup is the easiest for you to do, if you dont have the time to optimize your stock one, then the BAT will work.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
  10. #10
    May 2006
    Glen Ellyn, IL
    2,452
    well now it would just be cheaper to opt my stocker. i wonder if i can just get a msds y-pipe and no headers, but i would dout it. and yea i know everything needs to be tuned and big isnt always better
