Results 1 to 7 of 7
Thread: oil?
    Default oil?
    well i changed my oil today. but i am kinda worrying now. i've always used 5w30 regular oil (mobil or castrol gtx) for the past 3 years, and today i decided to go with synthetic. so i got some kind of engine flush thing. i put it in, left the car on idle fo 10min, then removed all the oil while still hot (bad idea but that's what the instructions were) and then added 5qt of mobile 1 5w30 full synthetic and 1qt of lucas oil conditioner for synthetic oil (or whatever its called).
    well the thing is that its a 98 E0 csvt with 106k+ miles on it. I know the engine has been changed by ford in 2000 so the engine should have less miles on it...but was that a bad idea? did i do it right? huh? should i have stayed with regular oil? I have red many people saying that leaks will occur (never had them so far). the guy at Auto Zone said that if the engine has ran on regular oil the first 5k miles, and then switch it to synth, it will destory all the gaskets, and the engine would be damaged pretty fast leading to rebuilding the engine...huh? true? have any of you changed to synthetic at high milage (say between 70-110k miles)
    i just need some opinions, coz as i searched the old forums, there are all kinds of statements.
    Sep 2000
    7,332
    It didn't hurt to switch to synthetic. You probably didn't need the flush. You most certainly did not need the Lucas Snake Oil. You probably didn't do any damage other than the dent in your wallet.
    Jim Johnson
    98 SVT
    03 Escape Limited
    LOL at the Autozone guy!!
    I switched at around 50k, I think. Simple drain and fill, with the engine warm. No worries.
    Function before fashion.
    '96 Contour SE
    "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
    Apr 2005
    Pillaging in Freedom, PA.
    3,876
    Switched to Mobil 1 @ 125k miles, no leaks so far. I was nervous about that too, but so far it was unfounded.
    Scott,
    1999 CSVT, Tropic Green, #2068
    "And that was all without even a single drop of rum" -Captain Jack Sparrow.
    If I'm a moderator, why don't I have groupies!?!
    Dec 2002
    Portland OR
    1,851
    If that car had used dino oil for a long time, doing the flush out was not a bad idea, sometimes putting in synthetic breaks up some of the accumulated gunk. You got some of that gunk out with the flush instead of having it suspended in your new fresh synthetic oil.
    MSDS SHO-shop Y custom 2.5" catback; xcal2; 63mm TB K&N 3530 Pud heatshield; Koni struts Aussie bar; THaines forks Quaife SpecII UR fly; DMD; UD pullies; Pole120 mounts. 92.03 trap speed: Just a daily commuter. SF/MB '98 SVT E0 #3159 8/21/97 178K miles
    sweet. so there's nothing to worry about? ) thanx
    now, in a few hours i will start to change my transmission oil. i am thinking to put the Mobil 1 synthetic automatic oil with 1/2 friction modifier. that'll be good right? thanx
    Sep 2000
    7,332
    Current thinking is that the best MTX fluid may be the newest Ford synthetic fluid. Also called "Ford Honey" for it's color. It's pricy though, at about $20.00 a quart.
    For this application, stay away from RedLine MTL. Many have reported that they have done well with Torco and Royal Purple. There have been threads on this recently if you want to search back a little.
    Jim Johnson
    98 SVT
    03 Escape Limited
